Xantia Idle problems
Morten
Unread post by Morten »
I have a '94 2.0 8V aut. which suddenly drops the idle to very low or stops. It appears when the engine is at normal operating temperatur. When I restart the engine, the idle speed rises very slowly to about 500 on the rev counter. This can happen many times a day, then it works normal for several days. I have not been able to se any pattern in this behaviour. Any ideas?
Richard Green
Unread post by Richard Green »
IAC valve, to test remove multi plug there are 4 pins A-D read 53 ohms and B-C 53 ohms, if that's OK clean the throttle body out and the IAC plunger " a good spray with wd40 " also look for vacuum pipe off or split.
Morten
Richard,
IAC Valve ? I need to have a look in the Haynes manual to see what that is
[:I]
Richard Green
Idle air control valve, this keeps the idle stable
106XS1998
Unread post by 106XS1998 »
Have you looked at the temp sensor? or the MAP sensor if the Xantia has one?
Richard Green
the TEMP sensor and the MAP sensor leaves a fault code and the engine warning light will come on, where as the idle control valve sticking wont but all the items are valued in the problem.
x 1431
My Dad had similar trouble with his 1.8 when it was hot in 2003. After a couple of weeks it just died completely. Needed a new crank shaft position sensor.
Richard Green
the symptoms of the crank sensor would cut the engine out rather than give erratic idle but it is worth mentioning it because it is a common problem to all cars these days, the wires to the crank sensor get brittle after a few years due to heat then they short out and in most cases the engine just dies.
Morten
Will start to check out the IAC. Is it worth the money to have the car checked for fault codes at a Citroen garage?
Morten
106XS1998
citroen will charge you about £40 for a fault code check, you could get your own fault checker for less! has your car got a map sensor?
Richard Green
now this my area 16 pin is the norm alda " computer connect point" ground pin 6 to earth and switch the ignition on the mil "engine warning light" will flash the codes, one long = ten and short busts= seconds and dont take it to a dealer, then take is fo a 20 mile run to restet the internal computer (its called a cysle)
Richard Green
ill talk you through it later because i'm not feeling well at the moment due to the heat.
