Yep same here, I just pity the person who has to clear it up when I've gone !!darbuck wrote: 14 Mar 2023, 13:48you and me both I have a shed full of car junk from over the years.
C5 X7 Steering Rack - Again!
Sloppysod
- x 382
Re: C5 X7 Steering Rack - Again!
Stu
darbuck
- x 291
- x 2285
Oh, my box of goodies has arrived!
darbuck
- x 291
Excellent, my seals have arrived, still waiting on sleeve will want to get a new bearing but will have to wait until I take it out. Weather still not letting up.
Darren
- x 2285
Sorry, which bearing?darbuck wrote: 17 Mar 2023, 18:38 want to get a new bearing but will have to wait until I take it out
The pinion bearing/bush ? I'd have thought that had a relatively easy life, not sure if that'll need changing.
Just to be clear the 6203zz bearing on my order isn't related to this job
darbuck
- x 291
I was thinking on changing it while I have it out. I will see how it feels when I have it out.
Darren
darbuck
- x 291
OnlineStickyfinger
- x 1983
Last weekend in August then.........
aerodynamica
- x 215
Watching your project with interest!
Graeme M
- x 2285
Darbuck is going to beat me at current rate, my rack is ok at present, I just worry enough about it to start accumulating bits "just in case"
Having said that, if I spot a rack cheap enough (and that free one went quick! But also a bit far away too) then I will likely attempt the project ahead of needing it.
I've bought a couple of the speedi sleeves (and four of the R23 type lip seals) mostly so I am not stuck if failed at first attempt at a fix.
Rest assured though, when I progress it, it'll be on here for all to enjoy (whether works or not!)
darbuck
- x 291
Darren
darbuck
- x 291
darbuck
- x 291
Just an update can't drop the subframe my jack finally gave up the ghost new one ordered. Have to prioritise other cars next week when it arrives, they need suspension and brake work. It will be May now before I get to the steering rack.
Darren
darbuck
- x 291
Hi All, I have finally pulled the steering rack, I had to drop the subframe to get it out, I had to drop the back of the subframe by about 4" to get enough clearance. I have taken the pinion out and stripped the bearing bush and seals. The bearing is rough so will replace it while I am at it, The shaft was actually in quite good condition a bit of pitting but not too bad I will sleeve it any way. There was loads of crap in the seal so only a matter of time. I am not changing any other seals apart from the two in the pinion housing. I am going to change the tie rods and tie rod ends. the sway bar bushings are worn as well so I am going to change them while I have the subframe lowered. I wouldn't like to be doing any of this with the engine in. I am starting to see light at the end of the tunnel on rebuilding this car.
Darren
Sloppysod
- x 382
It's not a problem, you disconnect the lower engine mounting and lower the subframe, it's alot easier gettjng the rack out if you have a pair of hands on each end of the rack.darbuck wrote: 18 May 2023, 19:54 ........ . I wouldn't like to be doing any of this with the engine in........
Stu
