2010 Nemo gearbox issues
NickTonTour
Unread post by NickTonTour »
Hi all.
2010 Nemo automatic. Cut out pulling away at a junction, now stuck in gear (although dash display says it’s in neutral). Now can’t start the car.
At a bit of a loss where to start diagnosing the problem. Any help would be greatly appreciate
Nick
x 6946
Re: 2010 Nemo gearbox issues
Please note that this is not an automatic - it has no torque converter. It has a manual gearbox and clutch, but these are hydraulically operated to do the manual gear changes and clutch operations by hydraulic actuators.
You need to have the vehicle diagnosed to be honest and then provide the fault codes and the VIN here.
NickTonTour
Hi, thanks for the response.
Sorry should have been more specific. I know it’s not a true automatic.
Thanks for the info. I was kind of expecting your answer. I will see if I can find someone to come out and run a diagnostic.
Nick
x 6946
No worries. These things can be awkward to diagnose, plus it is essentially a FIAT Fiorino, so is more FIAT than Citroen.
