Hi please can any help my Citroen dispatch 1.6 hdi is 2010 will crank no start this is the fault code
09B7
Short Circuit To +
Engine Relay Unit : Ignition Positive (+APC Relay Or Relay
Output Harness Fault
Any help will be appreciated
Thankyou
Citroen Dispatch
moizeau
- x 429
Re: Citroen Dispatch
You really need the diagnostics done on a tool that talks French (PSA). Diagbox/Lexia or a high end pro tool. That reader doesn't say which ECU/area of the car. I have the same van, maybe the crank/cam sensors not syncing but that is a guess without the full diag.
Pete
Saam1
Thankyou for your reply
I think that fault is stored on the Bsi
I think your right about getting it checked by
By someone who’s has the proper diag equipment
For these
Thanks again appreciated
For these
