508 GT - P0299 Turbocharger pressure regulation fault
rinor
Re: 508 GT - P0299 Turbocharger pressure regulation fault
hi im having simular problem peugeot 508 2011 2.2l hdi low boost but no foult codes i did a dyno test it reads only 155 hp at stage 1 i have 185 :/ ?
jxy127
Hi to whom might have this problem
Start by having the air mass flow sensor at the air filter diagnosed.
And be sure to use newest diagbox for this diagnose. I was using 7.12 or there about and getting the P0299 code for underboost. When i updated Diagbox to latest at this time 9.149 the code changed to P0100 air mass flow meter.
Changed the AMF and it's Like a brand New car.
Hope this helps so we can keep this fantastic car going a while longer
Best to you all
Best to you all
