Remove BSI from C3 Pluriel 2008
Gatto69
Unread post by Gatto69 »
Hi, has anyone tried to remove the BSI from Pluriel with Valeo j34p? I did have a look at it, it has a white frame/surround where the BSI is sitting, it is in vertical position, behind the ODB socket, i can't not see any possibile way to get it out without removing the glove box and everything that is on the way! Does it in some way slide out of this withe frame, or really i have to dismount all that staff? Please i you know will save me a lot of time.... Thank you
x 1056
Re: Remove BSI from C3 Pluriel 2008
Unread post by wheeler »
You need to remove the glovebox first, not that big a deal. About 8 T-20 screws.
Gatto69
Thank you, was quite easy only couldn't find out!
