x 6948
You didn't say front or rear, so here are both:
Front
(1) Frons Suspension Spring (Mark 3 Orange or 1 Purple), part: 5002VE, £184.14
Rear
(4) Rear Suspension Spring, part: 5102H1, £150.85
Tilly
x 5
Unread post by Tilly »
Hi. Looking for diagram and part numbers for the Nemo 1.4 power steering hoses. I can then select the hose, and get a price...
chassis number VF7**************[VIN obfuscated, can be read by forum staff]
x 6948
No problem, here is the diagram, just let me know which pipes you need part numbers and prices for:
Huskyxantia
x 928
Unread post by Huskyxantia »
Hi Marc part number for 207 rear wheel bearing
Vin VF3**************[VIN obfuscated, can be read by forum staff] many thanks
:-D
x 1498
Huskyxantia wrote: 11 Mar 2023, 19:43 Hi Marc part number for 207 rear wheel bearing
374890 (or 16 819 305 80 for the cheaper one)
Tilly
x 5
GiveMeABreak wrote: 11 Mar 2023, 12:14 No problem, here is the diagram, just let me know which pipes you need part numbers and prices for:
Cheers Marc, pipes 3 and 4 it seems....
x 6948
(3) Low Pressure Steering Pipe, part: 4012S0, £125.00
For pipe (4) there are 2 shown, so here are both the part numbers:
(4)Low Pressure Steering Pipe
Part: 4012Q1, £73.61
Part: 1651145880, £79.12
dylan26__
x 22
Unread post by dylan26__ »
Good Afternoon, Could you possibly assist me in the part number for the thermostat housing please for VF7**************[VIN obfuscated, can be read by forum staff]
Thank you :)
Huskyxantia
x 928
Hi marc, needing part numbers please for the following filters for the 207 vin number VF3**************[VIN obfuscated, can be read by forum staff]
OIL
AIR
FUEL
CABIN Thanks
:-D
x 1498
dylan26__ wrote: 12 Mar 2023, 15:56 Good Afternoon, Could you possibly assist me in the part number for the thermostat housing please for VF7**************[VIN obfuscated, can be read by forum staff]
Thank you :)
1336AX = £181.90 :(
x 1498
Huskyxantia wrote: 12 Mar 2023, 16:22 Hi marc, needing part numbers please for the following filters for the 207 vin number VF3**************[VIN obfuscated, can be read by forum staff]
OIL
AIR
FUEL
CABIN Thanks
OIL 1109AY @ £18.10
AIR 1444TV @ £34.88
FUEL 98 097 210 80 @ £58.66
CABIN 16 094 280 80 @ £31.08
All available much cheaper elsewhere!!
Huskyxantia
x 928
Many thanks Richard
:-D
danlat1415
x 24
Unread post by danlat1415 »
Please could you confirm the part numbers for the rear ABS sensor and sensor cable? (They come separately on my model)
VIN number is - VF7**************[VIN obfuscated, can be read by forum staff]
Thank you
x 1498
Sensor is 9800038580 @ £81.46
Wire seems to be part of a rear harness that includes the handbrakes and some other connections (that I imagine is a pain to fit!) - 9819297380 @ £109.24
x 6948
Bad news there I'm afraid Dan:
Rear Sensor
(2) Rear ABS Sensor, part: 9800038580, £81.46
There is no wiring shown with the rear ABS speed sensor diagram as you can see, unlike the front which have a harness on the driving wheels for obvious reasons.
It would appear to be attached to the main under-bonnet wiring loom (1). The rear connection harness (5) is then connected to the harness (1).
Where this harness is damaged as per the technical service bulletin, a repair is made to the wires where they have worn and started to short.
This harness shown at (5) is part: 9819297380, £109.24, but connects the other side and some other connections too. I think this is all joined somewhere in the intermediate or rear cabin floor.
