C5 X7 Steering Rack - Again!
Jay-Bruce
x 280
Re: C5 X7 Steering Rack - Again!
Unread post by Jay-Bruce »
Just a curveball suggestion, has anyone thought about using some of these nano-quartz superhydrophobic coatings to protect the exposed metal and repel moisture?
darbuck
x 289
Unread post by darbuck »
I thought about using them but they seem to need recoating annually so In the environment the shaft lives in I would say that is significantly reduced.
Darren
Jay-Bruce
x 280
Good point Darren, but sticking with the idea of super-hydrophobia, what about a super-hydrophobic waxoyl type of product - Buzzweld WAR - https://www.buzzweld.co.uk/war-underbod ... erwax.html
darbuck
x 289
Hi Jay Looks good maybe after doing the other mods as an extra layer of protection.
Darren
darbuck
x 289
Hi all, I know bobbins put a link up for the shaft seals but I just can't find it. Does anyone have it handy.
Darren
x 2366
Unread post by MattBLancs »
bobins wrote: 19 Jan 2023, 20:24 Found the oil seal references - do I win a prize ? :lol:
viewtopic.php?p=678803#p678803
viewtopic.php?p=578735#p578735
viewtopic.php?p=578681#p578681
MattBLancs wrote: 23 Jan 2023, 13:00 20x30x5mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC
https://simplybearings.co.uk/shop/Seals ... tml?page=1
£2.51 from Simply Bearings
Similar price on eBay too.
Think will get some ordered :)
I bought some on eBay, will find a link shortly
x 2366
darbuck wrote: 09 Mar 2023, 07:16 Hi all, I know bobbins put a link up for the shaft seals but I just can't find it. Does anyone have it handy.
I bought two of the R23 double seal type from this eBay seller:
https://www.ebay.co.uk/itm/295465727081 ... media=COPY
£4.03 delivered
darbuck
x 289
Thanks Matt
Darren
darbuck
x 289
A bit more expensive when posting across to Ireland. €15 delivered feck Brexit it added customs charges to everything. I need to get a suitable sleeve now I am thinking on getting some 21 mm ID stainless pipe and chem welding it to the shaft as well as the Speedi sleeve for the lower section before covering with a steering gaiter after modding the lump of course and leave the top of the shaft exposed for universal joint. I have a box of green O rings I can use on the HP pipes.do the gaiters have a pipe going into them?
Darren
x 2366
darbuck wrote: 09 Mar 2023, 12:05 A bit more expensive when posting across to Ireland. €15 delivered feck Brexit it added customs charges to everything. I need to get a suitable sleeve now I am thinking on getting some 21 mm ID stainless pipe and chem welding it to the shaft as well as the Speedi sleeve for the lower section before covering with a steering gaiter after modding the lump of course and leave the top of the shaft exposed for universal joint. I have a box of green O rings I can use on the HP pipes.do the gaiters have a pipe going into them?
Just for clarity, what's your plan with the stainless pipe? If just to keep the water away then I'd go for paint - don't forget the shaft has to pass through the lip seal , so you can't increase its diameter in any meaningful amount as wouldn't pass through. Speedi sleeve is stainless and very thin, so within the range of adjustment of the lip seal.
Ah that's a pain on the Brexit tax front. If can find a local engineering supply place, the lip seals are not exotic, might be able to buy locally instead?
darbuck
x 289
Thanks for that Matt I wasn't thinking of the lip seal so paint it is. Have the seals bought just need the sleeve and maybe one of those nano paints Jay suggested.
Darren
x 2366
MattBLancs wrote: 28 Jan 2023, 08:32 Searching on that part number
https://www.thebearingcompany.co.uk/pro ... CAQAvD_BwE
£10.53 + Vat, + £3.75+vat P&P costs.
Gone up to £11.06+VAT (p+p still £3.75+VAT) for the speedi sleeve
darbuck
x 289
I ended up getting the sleeve from a company here in Ireland. I got gouged again €42 delivered. There's some serious gouging going on here at the moment.
Darren
x 2366
That link I found seems very cheap £17.74 delivered, there's lots of them in the £22 to £29 range for the same thing but can see that is still a chunk cheaper than what you've been able to find. Frustrating!
darbuck
x 289
Yeah have it all bought now. Just have to wait now.
Darren
