citroen berlingo starting issue
grish art
Unread post by grish art »
Hi all
I have a starting issue with my citroen berlingo 2003 hdi 2.0
It came up with an error with an injector which i replaced, but still wont start. It cranks but there is no fuel getting to the rail. I have a siemens pump (as in the picture) I am trying to replace and test the solenoid on the pump.
I have a couple of questions.
1. how do i remove the Solenoid and test it?
2. how do I find out what the make and number of the Solenoid is to replace it?
Thanks for an advice you can give.
Huskyxantia
x 925
Re: citroen berlingo starting issue
Unread post by Huskyxantia »
Guessing here would the solenoid unscrew ?
:-D
grish art
I have removed the part, but can't find the part number. it says .C1 5 0138 .3 but i cant see what this referes to get a replacement. How do I find the part number?
Huskyxantia
x 925
They should have a silver label on with all numbers needed
:-D
Huskyxantia
x 925
But looking at your pictures its been sprayed or powder coated black , so that wont help
:-D
Huskyxantia
x 925
:-D
