- x 6945
Rear Sensors:
(2) Part: 9677782980, £164.65
As for Front Brake Discs:
There could be a possibility of 2 types, Bosch or Brembo fitted.
The standard Bosch is 283 mm, the Brembo is 323
dylan26__
- x 22
Awesome, Thank you Marc have a good weekend!GiveMeABreak wrote: 04 Mar 2023, 14:45 Rear Sensors:
Dustysweeper
- x 20
Ok replacing the loom is out of the question. Im wondering if it's worth replacing the sensor with an OEM one instead of the Euro car parts replacement It has now. Could you provide part number for the Rear right ABS sensor please?GiveMeABreak wrote: 01 Mar 2023, 19:18Hi Duncan. The harness shown Item (5): part: 9810156480, £473.44 inc. VAT, so you may be better off repairing the relevant section.Dustysweeper wrote: 01 Mar 2023, 18:10 I am looking for the part number for the rear ABS wiring with connectors (not the sensors) it's the section of wiring that runs from the rear wheels to the connectors that are underneath the carpet in the rear.
Many thanks
Duncan.
Vin... VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Duncan.
- x 6945
If you'd mentioned ECP to start with, I would probably have cautioned against getting anything like this from them, they are notorious here for poor quality parts, so it is a distinct possibility, assuming there are no other breaks or issues.
(2) Rear ABS Wheel sensor, part: 9800038480, £81.43
508c5
- x 4
Hi,
Couldn't find the part number for this hose (actually, the rubber seal which covers the throttle (under number 7 clamp) is what I need) - the number indicated on it won't bring up any results - pls. help if you can...(PEUGEOT 508 1.6THP, 156BHP - I GUESS ALL THP ENGINES HAVE THIS ONE)
- x 6945
Ok, so that's the Turbo Air Intake Pipe:
(1) Turbo Air Intake Pipe, part: V763335580, £204.30
(22) Air Duct End Peice, part: V758424680, £9.35
Got there in the end. I've removed the last irrelevant posts now we've ascertained the correct part.
jakuboz
Hi,
can I please have parts number for drive shafts (left and right), and hand brake cables (left/right) for VF3**************[VIN obfuscated, can be read by forum staff] ?
Searching with TecDoc gives at least three results for each part, with slightly different measurements...
Thanks in advance.
Thanks in advance.
- x 6945
@jakuboz, here you are:
Driveshafts
Please note that none of these Driveshafts are currently available from Peugeot as they are no longer produced, but you can use the part numbers for aftermarket alternatives:
Left
Item (1)
Peugeot OEM New Driveshaft (Wheel Side Joint GE86 & Axle Side Joint GI69), part: 3272T3 (No Longer Available)
Peugeot Approved Cheaper Alternative (Wheel Side Joint GE86 & Axle Side Joint GI69), part: 3272H7 (No Longer Available)
Right
Item (2)
Peugeot OEM New Driveshaft (Wheel Side Joint GE86 & Axle Side Joint GI69), part: 3273Z5 (No Longer Available)
Peugeot Approved Cheaper Alternative (Wheel Side Joint GE86 & Axle Side Joint GI69), part: 3273Q1 (No Longer Available)
Handbrake Cables
Left
Item (5):
Peugeot OEM New Secondary Brake Cable, part: 474597 (Long 1656), £70.79
Peugeot Approved Cheaper Alternative, part: E074033, £18.30
Right
Item (5)
Peugeot OEM New Secondary Brake Cable, part: 474598 (Long 1565), £70.79
Peugeot Approved Cheaper Alternative, part: E074034, £20.15
Driveshafts
Left
Item (1)
Right
Item (2)
Handbrake Cables
Left
Item (5):
Right
Item (5)
ChrisW
They suggest changing the voltage sensor which is built in to the negative battery cable at a cost of £450 as a starting place.
Could you give me the part number I think I will get one from a breakers and try it myself. My vin is VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks in anticipation.
Admin Note
Technical Query moved to new post here:
viewtopic.php?p=747872#p747872
Admin Note
Reason: Split Post
Reason: Split Post
- x 6945
The info you requested is below Chris, however I would counsel against that advice! I will copy your post to the Citroen Technical Section, leaving the original here, so that any further discussion is outside this 'Parts' thread.
Link to post:
Item (10, Battery Charge Status Unit, part: 9804833280, £120.96 inc. VAT
Link to post:
Orbit Motors
- x 19
Good afternoon Marc,
My Offside Front wheel bearing on my C6 is now becoming in real need of changing, but I feel that changing the hub itself may be the best option, can you show me a breakdown of parts in that region please? And also just for information, does the bearing have an exciter ring of some sort for the ABS inbuilt as I'm getting intermittent faults for the OSF ABS sensor which could be related to this.
Many thanks!
Many thanks!
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
Miles
- x 6945
I believe the magnetic wheel / ring is incorporated into the front bearing. Here's the schematic:
Let me know any items you require part numbers for.
Orbit Motors
- x 19
D, 3, 28, 29 and 30 look the most relevant.
Out of interest can you look up part group 1 as well?
Many thanks!
Many thanks!
Cheers,
Miles
Miles
- x 6945
D is not available separately from Citroen Miles, it is part of (1), the Front Stub Axle Carrier, which includes all the parts (A, D, 3, 14 & 31).
So...
(1) Front Stub Axle Carrier
Left, part: 1640790280, £423.64
Right, part: 1640790480, £462.13
(3) Front Wheel Hub, part: 330780, £93.34
(28) Holding Pin, part: 329703, £1.57
(29) Wheel Hub Fixing Kit, part: 329733, £4.24
(30) Locking Nut, part: 9808870380, £5.15
So...
- x 1072
I need real help with this, my C8 broke a spring, what a b1tch, I need the parts numbers please.
Champion of Where's CitroJim
