Xantia fans working overtime!
Clogzz
- x 40
ktaylor21662
Clogzz
- x 40
On mine, it was the one furthest away from the front.
Since your arrangement is different, it's a matter of experiment.
To know, pull any one out and then turn on the air conditioner...that will make the fans spin at the low speed.
If they don't...you've got the wrong fuse out.
Switch off, put back in, remove the other one, switch back on...if fans spin at the low speed, you've got it right.
Don't remove fuses while the aircon is on...it will spark.
ktaylor21662
ktaylor21662
