xantia rescue
x 5626
Re: xantia rescue
x 3283
Re: xantia rescue
You might find this useful;
http://www.eastment.net/hcrefurb/index.htm
Scottculli
x 29
Re: xantia rescue
Unread post by Scottculli »
My bad guys I meant to say id finished the height corrector but was wondering if anyone had a guide for the controll block 😅but thanks anyway.
Scottculli
x 29
Re: xantia rescue
I was gonna save them for later but heres a couple of pics of how it got on
quintet
x 44
Re: xantia rescue
Unread post by quintet »
Thats a heck of a lot of work your doing on this car. mighty impressive =D>
Music keeps me going.
Scottculli
x 29
Re: xantia rescue
hey everyone i hope your all doing well,sorry for the long time not posting i said id post when i next made big progress but i just kept pushing back my goalpost,but i think you might like the work anyway even if its not all been complete.
the main target ive set has been plugging some of these rust holes that make it qualified to be called a sive and taking of the underseal
ive bought myself a welder and have been learning to weld as i go along ive welded in a few peices the progress is coming along even if it is not doing so quickly
i will be back again soon for another update as well. i hope you have enjoyed it, thanks Scott
Skull
(Donor 2026)
x 372
Re: xantia rescue
Unread post by Skull »
Good to see you're persevering with this Scott - I'm not a welder although I did attempt some 20 years ago, yours looks a pretty good effort for a beginner =D>
Gary
x 8234
Re: xantia rescue
Good work Scott :D Keep those updates coming ;)
Scottculli
x 29
Re: xantia rescue
CitroJim wrote: 25 Feb 2023, 05:13 Good work Scott :D Keep those updates coming ;)
Thanks, i will do :-D
Rhothgar
(Donor 2026)
x 222
Re: xantia rescue
Unread post by Rhothgar »
Loved reading your blog whilst searching for brake doseur return line leak posts…
Huskyxantia
x 835
Re: xantia rescue
Unread post by Huskyxantia »
Great job
:-D
x 2263
Re: xantia rescue
Unread post by MattBLancs »
Scottculli wrote: 24 Feb 2022, 20:41 i have removed the exaust goten the idea to get it to a mirror finish realised it would take way to much effort
and just left it like this i might finish this off later to be fair but i think im going to use a ruffer grit sand paper on the angle grinder to make it quicker.
thanks for reading
scott
Hi Scott,
Apologies if meant in jest, but I wouldn't attempt to polish up a mild steel exhaust, if you want it shiny then would be better getting something made in stainless steel.
Think mild steel would be a constant battle to keep shiny and between the corrosion and you grinding/ polishing it back again you'd eat through the thickness of it on short order! :)
Scottculli
x 29
Re: xantia rescue
hey everyone thank you for all the kind words of support, ive been reading tham all and i really appriciate them, im sorry everyone for not uploading for a really long time i kept telling myself i would upload a update when i felt i had made some real progress but every small step forward i never thought was enough but now looking in hindsight i have still done a fair bit of work and learnt a lot of skills in the processes
to start i finished off the sill work as from my last post so i moved on to looking at the rust behind the wheel arch(gulp :shock: ) i was in for a suprire, i took of the bumper and decided i would go from there tjis is what i saw
the result was worse than i had expected, so if i wanted to tackle the structural issue i was going to have to take off the wing the wing is not like the front where you are able to unbolt it it is welded on so i had to drill out about 60-70 ish welds until i got this one wing that now currently lives in my room and is a great toe stubbing device when walking in the dark at 2 in the morning :-D
from here that gave me a great picture to see where i was at ( ironically i didnt take a picture of the car at this point) all of the individual structural parts of the rear chassis where completely rusty so i drilled them all out individually and began on restoring them with some sheet metal and my
welder
and from there i got to the main structural point of the chassis leg
this large rectangular tube section which was completely rusty so that is the present point i am on is using a buck to recreate the shape of the tube to put in new steel .
thank you everyone who has read this and for the patience for me taking so long to upload, Scott
Skull
(Donor 2026)
x 372
Re: xantia rescue
Wow 😮 That is way beyond what I could attempt Scott …. Great to see this amount of commitment to your Xantia =D>
Gary
Skull
(Donor 2026)
x 372
Re: xantia rescue
Scottculli wrote: 07 Dec 2020, 19:53 Luckily my drive is brick,……but going on the rest of the car I'm confident it’s pretty rust free. it’s the 3.0l v6 that comes with the exclusive model, and it was made in 1998.
The hidden killer normally [-o<
Gary
