Energy Matters Global and Domestic
- x 8137
Re: Energy Matters Global and Domestic
Considering that in January I implemented the garage ventilation fan, 150W, and an hour a day of fan heater, 600W, we have still improved on previous years for February!
So I did the off peak hour, shut off all the electrics, this is the result.
- x 1940
It struck me that people who are already frugal in their consumption would stand little chance of further reducing their consumption in order to qualify for a reward and your screenshot proves me right.
But then again, it might encourage the profligates amongst us to dial down their consumption. Which, I suppose, was the point of the exercise anyway.
- x 8137
Those numbers don't make sense to me Gibbo, they seem to have added your normal consumption to the special consumption to give the saving!! How could the saving be more than your original consumption? Surely that should show a saving of 0.581-0.02 =0.561kWh? Or am I going doolally?Gibbo2286 wrote: 21 Feb 2023, 13:23 So I did the off peak hour, shut off all the electrics, this is the result.
Plus if you get prize draw entries for each 0.1kWh saved you should have got 5 ! ????
- x 3296
There is a program series on Channel 4; Guy Martin's Great British Power Trip. The most recent episode had him at one of the most secure locations in the UK; the National Grid ESO. Typically 2% of your electricity bill pays towards running this site, which is responsible for managing the whole of the National Grid. They buy in power to make sure the Grid stays stable. The objective is to keep the frequency bang on 50Hz. If it is over then there is too much power on the Grid, while lower means not enough power. They have to buy the power from each of the generating stations. Normally they spend £2M a day! To get into the control room you have to pass through an 'airlock', where both doors require a different PIN. Get it wrong and not only will the Police be called, so will the Army!
My thoughts too Mick, I'm going to ask for an explanation.mickthemaverick wrote: 21 Feb 2023, 14:28Those numbers don't make sense to me Gibbo, they seem to have added your normal consumption to the special consumption to give the saving!! How could the saving be more than your original consumption? Surely that should show a saving of 0.581-0.02 =0.561kWh? Or am I going doolally?Gibbo2286 wrote: 21 Feb 2023, 13:23 So I did the off peak hour, shut off all the electrics, this is the result.
Plus if you get prize draw entries for each 0.1kWh saved you should have got 5 ! ????![]()
- x 1940
Not as secret as Guy Martin would have you believe.Hell Razor5543 wrote: 21 Feb 2023, 14:35The most recent episode had him at one of the most secure locations in the UK; the National Grid ESO.
https://en.wikipedia.org/wiki/National_ ... f_the_grid
Well I contacted Shell about this, got a phone call from them this morning saying they had put the infrmation in another email because it was too complicated to explain over the phone, I'm baffledGibbo2286 wrote: 21 Feb 2023, 16:18My thoughts too Mick, I'm going to ask for an explanation.mickthemaverick wrote: 21 Feb 2023, 14:28Those numbers don't make sense to me Gibbo, they seem to have added your normal consumption to the special consumption to give the saving!! How could the saving be more than your original consumption? Surely that should show a saving of 0.581-0.02 =0.561kWh? Or am I going doolally?Gibbo2286 wrote: 21 Feb 2023, 13:23 So I did the off peak hour, shut off all the electrics, this is the result.
Unadjusted Baseline (UB) - this is an average per hour of usage from the last 10 working days (if event during the week) for every hour of the day
Within-Day Adjustment period (WDA) - this is taken from a 3 hour window that day, closing 1 hour before the event starts (eg 1pm -4pm if event is at 5pm) of actual usge within that 3 hour period. This is to take into account any changes of usage on that day (eg working from home that day due to weather or sickness)
Adjusted Baseline (AB) - takes into account variations of actual usage v average 10 working day usage
*This is all taken directly from National Grid and their methodology and is consistent across every supplier
If you had any figures of your own , please don't hesitate to reply to this email to go over your findings.
- x 8137
That doesn't explain any of the figures on the original post and introduces numbers which were not even there!! I would respond to that email asking for an explanation of the actual numbers on the original post and a further clarification in English of the cobblers contained in that email!!
- x 3565
It's actually quite easy to work out the methodology - your energy company wins and you don't. Simples.
- x 2356
"blinding you with science"
- x 8137
The only science involved there would be the biology of male cattle excrement!!
- x 1240
Are you plugged into a lamp post outside Mick?mickthemaverick wrote: 21 Feb 2023, 14:28Those numbers don't make sense to me Gibbo, they seem to have added your normal consumption to the special consumption to give the saving!! How could the saving be more than your original consumption? Surely that should show a saving of 0.581-0.02 =0.561kWh? Or am I going doolally?Gibbo2286 wrote: 21 Feb 2023, 13:23 So I did the off peak hour, shut off all the electrics, this is the result.
- x 8137
Did you mean to ask Gibbo that Peter?Peter.N. wrote: 23 Feb 2023, 11:55Are you plugged into a lamp post outside Mick?mickthemaverick wrote: 21 Feb 2023, 14:28Those numbers don't make sense to me Gibbo, they seem to have added your normal consumption to the special consumption to give the saving!! How could the saving be more than your original consumption? Surely that should show a saving of 0.581-0.02 =0.561kWh? Or am I going doolally?Gibbo2286 wrote: 21 Feb 2023, 13:23 So I did the off peak hour, shut off all the electrics, this is the result.
- x 1240
