Replaced injectors on my euro 5 2015 boxer. New seals and bolts plus a new leak off pipe.
Engine cranks over but wont start up. Getting the P2291 26 code.
Please see attached the reading from diagbox. Any advice is welcome.
Thanks.
P2291 26 fault
- x 6950
Re: P2291 26 fault
Here you go:
| Fault Code: | P2291 26 |
| Description of Fault: | Starting monitoring: Pressure increase in the injection rail too slow when starting. On starting, the fuel high pressure common injection rail pressure requested is not attained at the end of 12s. Conditions of activation of the diagnostics: Engine starting. |
| Conditions for Fault to clear: | Under starter. |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
malc4
- x 3
Re: P2291 26 fault
My friends P2291 turned out to be air in fuel system due to some numpty mechanic only fitting one of the 3 bolts on the fuel filter housing...
