My partner teepee wont start, I get one start of a crank then nothing, except the wiper comes on and I get a message about engine fault get it repaired. This happened a few weeks ago in the cold spell and I thought it was a flat battery, but after 5 or 6 tries it turned over fine. Now it wont, get some clicking noises too and eratic small needle movements when trying to start. What should I do, Im no mechanic. Its a 2016 Auto Hdi by the way.
Any help much appreciated.
Partner Teepee wont start
Dormouse
- x 696
Re: Partner Teepee wont start
Hi and welcome. There are a few threads on poor starting behaviour in here. Look at the very top left of the page and you will see a small box which says "google search". Write " won't start" in it and click the magnifying glass. You can find how others have found information about starting issues.
Don't worry though, others will come on and ask you for more information to help you.
You might want to check that your battery leads all have good connections as this is a possible issue. As I say, others will pitch in.
- x 1056
Battery connections clean & tight?
Any work been done recently?
I'd want to get a volt meter on the battery whilst you try starting it to see what's happening there.
can you get jump leads on it to rule out the battery?
