Citroen C5 X7 headlights died
Viitonen
- x 11
I’ve got X7 2010 with halogens. All the lights were ok, I stopped for couple of hours and started the car. No headlights! All the other lights are ok. Fuses and bulbs are ok. Where is the relay located? Any other suggestions?
- x 1939
Re: Citroen C5 X7 headlights died
Do they work on main beam? Either as headlights or when you flash the lamps? Do the sidelights come on?
Are you running them as auto lamps on? What happens if try manually?
- x 1055
Have you replaced the bulbs or replaced them direct on a battery?
Viitonen
- x 11
Strange! Now they work just fine!
Citroen - the car that repairs itself
