Removing
Slacken the pressure take-off union (5).
Remove:
- The (7) bolt
- The bracket (1)
- The (6) bolt
Remove the collar (4).
Uncouple the particle emission filter (3) (at "a").
Remove the 4 mountings (2).
Detach the particle filter (3) from the catalytic converter .
Remove the seal (which must be replaced on refitting)!
Refit:
Seal (new)
The particle emission filter (3)
The 4 mountings (2)
Couple up the particle emission filter (3) (at "a").
Refit:
- The clip (4); Tighten to 2,6 daN.m
- The pressure take-off (5)
- The (6) bolt; Tightening to 0,6 m.daN
- The bracket (1)
- The (7) bolt; Tightening to 3,3 m.daN
