x 6955
ntinakos90 wrote: 30 Jan 2023, 12:27 Hi Marc,
I am assuming the first digit for the above part number for the steering rack is 9 instead of 1? Can you please confirm if the above number is also equivalent to 4001 63 or 4001EA.
Regards
Konstantinos
1) The part number is correct as listed (1610577580). This is the latest replacement part.
2) The old part was 400163 now replaced with the above not 4001EA which is not compatible with your vehicle (that's why we use official Citroen parts data from your vehicle VIN).
x 6955
Orbit Motors wrote: 30 Jan 2023, 15:14 Hi Marc,
Peugeot 306 again, VF3**************[VIN obfuscated, can be read by forum staff]
I'm after a set of injector seals (copper washers, fire washers) and sleeves please.
Many thanks
Here you go, with this engine there seems to be loads, even with the VIN, so I'm listing the lot:
199080 EP 0,80
199081 EP 0,84
199082 EP 0,88 (No Longer Available)
198950 EP 0,90
198951 EP 0,94 (No Longer Available)
198967 EP 0,98 (No Longer Available)
199085 EP 1,00 (No Longer Available)
199086 EP 1,04
198930 EP 1,10
198931 EP 1,14 (No Longer Available)
199090 EP 1,20 (No Longer Available)
199091 EP 1,24 (No Longer Available)
198934 EP 1,30 (No Longer Available)
198935 EP 1,35 (No Longer Available)
199095 EP 1,40
199096 EP 1,44
198938 EP 1,50 ROBERT BOSCH
198940 EP 1,60
1990A0 EP 1,64
198942 EP 1,70
198943 EP 1,74
1990A2 EP 1,80 (No Longer Available)
198945 EP 1,84
198946 EP 1,90
198947 EP 1,94 (No Longer Available)
198968 EP 1,98
darbuck
x 290
Unread post by darbuck »
I am looking for the part number for the hub and steering Knuckle carrier
Darren
x 6955
It it's item 8 you want, then:
Front Wishbone Arm Mounting, part: 3523AQ, £26.12
If other, please advise of item number.
darbuck
x 290
Hi Marc, it's part B in diagram I'm after.
Darren
x 6955
Ok, so that is a combined kit that includes B, (12) & (13).
(2) Front Hub Carrier Support Left part: 365604, £495.12
(2) Front Hub Carrier Support Right part: 365704, £495.12
C5X7_2_2HDI
(Donor 2022)
x 4
Unread post by C5X7_2_2HDI »
Hello Marc!
I will most likely have to replace EGR cooler on my C5 x7.
So I was hoping you could provide me with the part number(s).
My VIN nr. is VF7**************[VIN obfuscated, can be read by forum staff]
And could you be so kind and post the procedure for EGR replacement on a 2.2 Hdi?
Thanks in advance Marc and have a good one :)
x 6955
Ok, so this is a complete module:
Item (1) Emission Control Module
OEM Original part: 9678163380, £1316.65
Standard Exchange Module, part: 1679827880, £1244.57
I'll put a procedure up later in the members resources section.
Update:
Procedure Here
wfdTamar
Unread post by wfdTamar »
When you post a part number with a price does it always include VAT?
2015 C5 Limited Edition (2.2 HDI) 150 kW 450Nm (Racechip S 179kW 528Nm)
x 6955
Yes, UK prices of course Bill, with our 20% VAT included.
Pulstar
(Donor 2022)
Unread post by Pulstar »
I would really like to get a diagram of the upper part of the dasboard where the dash is fixed on the chassis. Have a strange rubbing rattle when i accelerate/decelerate that seems to be coming from the dashboard/windshield area.
My VIN number is: VR7**************[VIN obfuscated, can be read by forum staff]
Thanks, B
x 6955
These are the parts diagrams available: Click to zoom.
moizeau
x 429
Unread post by moizeau »
Afternoon Marc, could you please supply the part numbers for the front wheel bearing and ABS sensor for my Dispatch. Also sealing washer for the sump when doing an oil change (I've forgotten the word for it in English) for the Dispatch and also my 407 please?
Much appreciated, cheers.
Pete
x 6955
@Moizeau Dispatch
Front Abs Sensor Dispatch
(1) Front ABS Wheel Sensor Part: 4545E9, £84.52
Front Hub Bearing Dispatch
(4) OEM Original Part: 1617969780, £130.01
Citroen Cheaper Alternative, part: 1681931180, £43.01
Oil Sump Drain Plug Seal Dispatch
(4) Part: 1682801680, (21X10-1,5 DRAIN PLUG SEAL, DIAMETER 10) £1.49
x 6955
@Moizeau 407
(3) Oil Sump Seal (14X21-2 WITHOUT ASBESTOS - A005-) part: 031327, £2.93
