Hi there,
I have an annoying kind of popping noise that seems to come from both front doors seals of my DS5 (of 2011), it looks like a friction noise between highly dried seals and that can be heard only when the weather is dry (never when humid/rainy).
Could anyone help me to solve this issue please?
I was thinking of replacing the front left and right window channels (the kind of rubber seal that surrounds the top of the window, the part number seems to be 9687802080 and 9687801980), but these are very pricy and I am not sure it will help much. However these window channels look highly used and torn at angles so I think it may also decrease isolation and increase air noise.
Your help will be highly appreciated.
Many thanks
DS5 noisy door seals(?)
- x 6957
Re: DS5 noisy door seals(?)
You'll only get these from the dealer - they don't make these anywhere else as far as I'm aware.
Have you checked the actual door seals themselves? I suggest you smear a little grease on the outer facing of the rubber which may solve the noise. Often the cause can be in icy or very cold conditions where the door seals have moisture and can freeze, which are then damaged over time as the doors are opened.
Tommy2001
Thanks for your quick reply Marc, much appreciated!
Yes, I did check the door seals and cleaned them first as they were very dirty.
I will share some pictures tomorrow to show their aspect and will try to smear some grease on them but if you have any specific grease to recommend it will be great. I am wondering if any TSB related to this issue were released.
But even in not cold conditions this noise occurs unfortunately.
OnlinePaul-R
- x 1942
Petroleum jelly (Vaseline) would be better than grease as such.
- x 2343
Red rubber grease is safe on rubber components:
https://www.ebay.co.uk/itm/203011115035 ... media=COPY
Have also hear good reports on Silicone Spray in similar application
https://cpc.farnell.com/c/sprays/silico ... rt=P_PRICE
Tommy2001
Understood Paul, thanks a lot!
Thanks as well Matt, I will give it a try.MattBLancs wrote: 03 Feb 2023, 21:07 Red rubber grease is safe on rubber components:
- x 2343
Just watch out with the silicone spray - Keep away from anything you don't want slippy! e.g. steering wheel. It's good stuff but tends to "get about" and find other things unintentionally lubricated too (in my ham fisted experience anyway!)
- x 5674
Indeed it does.MattBLancs wrote: 03 Feb 2023, 22:49 Just watch out with the silicone spray - Keep away from anything you don't want slippy! e.g. steering wheel. It's good stuff but tends to "get about" and find other things unintentionally lubricated too (in my ham fisted experience anyway!)![]()
I worked in a photostudio that had previously been a sewing factory. There were lots of odd things left behind including cans of silicone spray.
We had huge workbenches that were light-boxes, to review the photos on. These were diapositives, 'slides' to most but mostly 9 x 12 to 18 x 24 cm and were for lithographic reproduction for magazines and catalogues, not projectors.
Clients and models would come to have a look at them and would have cups of coffee/glasses of wine with them, that they would place on the lightboxes. We found it amusing to spray the lightboxes with silicone and watch the coffee/wine slide to the other end of the lightbox and fall off.
Very juvenile but the shock on faces was well worth having to clean up the mess.
Tommy2001
Hi guys,
A quick update, I ordered and used below product on all the doors seals a few days ago and it seems to work, at least for now, no door noise anymore! I will let you know in upcoming weeks/months if still works.
NEXTZETT Rubber care gummi pflege
- x 6957
Thanks for the update Tommy.
robdevil
- x 8
In my case I've had a little crack in the corner. Bit of gorilla glue did the job. Over a year now an no problem with seal noise.Tommy2001 wrote: 06 Apr 2023, 08:48 Hi guys,
TailorBenny
Hey there !
Wanted to say a big thank you, it helped me identify the squeaky noise in the doors, which I had lived with over a year. These plastic (or rubber) materials worned out, and made contact with the metal part of the door, which made these sounds. Before that, i changed the clips which hold the panel, and also applied some grease on the door rubber, but nothing helped, and it drove me crazy. The frustrating part was that, sometimes it stopped and the car was silent. I noticed it, when the air was humid after rain, or I washed the car, it somehow stopped.
Sadly, I can also confirm, these seals still have horrible price, short therm solution is putting some Citroen branded seals under the parts you mentioned in the post. I could buy them used, but I think there is no point to.
