Peugeot 306 (2001) heated rear window, not working
onejon1
x 4
Unread post by onejon1 »
Hi All,
Any tips for getting my heated rear window, working again and a suggested order for chasing any faults?
Also, does anyone know where I can get one of these for a less eye-watering amount?
x 2313
Re: Peugeot 306 (2001) heated rear window, not working
Unread post by MattBLancs »
Have a good look at the relay in the fusebox under the steering wheel - no sign of my heated screen relay, but a somewhat melted socket where it should be! I can take a picture, but not sure when I will get chance (maybe next weekend before I have time to get at the 306 in daylight)
Not as good as a new one, but some on eBay, e.g.
https://www.ebay.co.uk/itm/266085870005
onejon1
x 4
MattBLancs wrote: 22 Jan 2023, 20:56 Have a good look at the relay in the fusebox under the steering wheel - no sign of my heated screen relay, but a somewhat melted socket where it should be! I can take a picture, but not sure when I will get chance (maybe next weekend before I have time to get at the 306 in daylight)
Thanks, Matt.
Which one of these is it?
Is it D?
For future reference, could you label these relays, please?
A=
B=
C=
D=
E=
F=
G=
H=
x 2313
Hi,
From memory, think you are right, its the big orange one (D) that I'm missing (and would be the heater rear screen) but if you can hang on till the weekend I will check and confirm.
I thought I had seen a labelled up relay diagram, but can't think where! It's not Haynes, just checked there.
picassodad
x 15
Unread post by picassodad »
The functions of the labeled relays would be very usefull for me to.
On our 306 estate, the wires going to the heated rear screen were fatiwued and broken. Fixed them only to find that half of the heated screen elements worked.
Still half a screen is better than none.
picassodad
x 15
If possible, could relay part numbers be included. I have the green ones and orange, but not black and grey.
Info greatly appreciated.i assume correct colour relays in correct places ?
Also, fuse numbers as seen in picture.
Looking at picture, fuses top row left is fuse 1 etc. ?
x 2313
Some info here:
https://catalogs.ssg.asia/peugeot/?lang ... BwbGllcj09
Will see what I can see tomorrow, can't promise I'll be able to identify the lot! :)
