C5 X7 Steering Rack - Again!
x 3296
Re: C5 X7 Steering Rack - Again!
The shame is that the C5 X7 looks like it is a useful car, but let down by some components being built to a price. Because of the steering rack issues I will not willingly get an X7, and I doubt other Forum members will either, unless they can get a solid refurbished rack that has been built to last (if such a thing exists).
x 3565
MattBLancs wrote: 19 Jan 2023, 19:05
Mentioned that lip seal is commonly available - can anyone confirm the details (and / or double lip version) ?
I may get a seal ordered for when mine joins the club...
Bear with me whilst I delve into the dim and distant past. I posted about the double lip seal years ago on one of the steering rack threads on FCF.
Talk quietly amongst yourselves whilst I find the post :-D This may take some time :lol:
aerodynamica
x 215
Unread post by aerodynamica »
GiveMeABreak wrote: 19 Jan 2023, 19:12 I loved my X7, spared no expense, but not long after the third rack was fitted with the mod, I reluctantly made the decision to move her on as I knew critical parts were also starting to become unavailable. The first 2 racks were genuine Citroen ones, the second one perishing a few years after the original, however when I sold her the refurbished rack was still looking good.
Actually didn't realise you sold yours Marc.
Graeme M
x 3565
x 2354
Unread post by MattBLancs »
bobins wrote: 19 Jan 2023, 20:17
No rush, at least I hope not for me at least!
x 2354
bobins wrote: 19 Jan 2023, 20:24 Found the oil seal references - do I win a prize ? :lol:
viewtopic.php?p=678803#p678803
viewtopic.php?p=578735#p578735
viewtopic.php?p=578681#p578681
Definitely! Swift and efficient :-D
Much appreciated
x 2354
Hell Razor5543 wrote: 19 Jan 2023, 19:19 The shame is that the C5 X7 looks like it is a useful car, but let down by some components being built to a price. Because of the steering rack issues I will not willingly get an X7, and I doubt other Forum members will either, unless they can get a solid refurbished rack that has been built to last (if such a thing exists).
Strangely I think the X7 despite being nearly a decade younger, is in a very similar boat to my 406 Coupe - not worth enough to lavish huge sums on reverse engineering no longer available parts, not common enough to have those on the road sustained by a near endless supply of crashed, broken ones generating spares cheaply and readily (or the classic Ford approach - survivors now worth a fortune, but actual survival rate close to zero!)
I've been pleased to read of folks trying to overcome these design / manufacturing quality / material choice common failure modes - and given the dismal support from Citroen themselves, this will be what makes or breaks X7 viability, certainly as an everyday car.
Hmmm. I nearly bought a second hand rack a bit ago. Might have another search.
Ceenine
x 17
Unread post by Ceenine »
You are all obviously driving in the wrong part of the world: no steering rack problems down under.
x 2354
20x30x5mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC
https://simplybearings.co.uk/shop/Seals ... tml?page=1
£2.51 from Simply Bearings
Similar price on eBay too.
Think will get some ordered :)
x 2354
Just looking at speedi sleeves, based on a 20mm shaft, this would seem a contender:
https://www.ebay.co.uk/itm/143251082534
£27.12 including postage, not sure the going rate for these, bit more expensive than I would have guessed. Will keep digging.
Couple of R23 lip seals in my eBay shopping basket at present :)
x 2354
Searching on that part number
https://www.thebearingcompany.co.uk/pro ... CAQAvD_BwE
£10.53 + Vat, + £3.75+vat P&P costs.
x 2354
Timken redi-sleeves
https://cad.timken.com/viewitems/seals/redi-sleeves
From here suggests 99078
Max shaft diameter 20.041mm
Min 19.939mm
Eventually the penny dropped!
SKF number: CR99078
Timken number: 99078
:-D
MattConn
Unread post by MattConn »
Does anyone have any ideas where I could track down a set of power steering pipes for my X7.
I fitted a recon rack about 30k miles ago and a coating of high vac grease has kept the pinion shaft in good shape. I now seem to have the LP pipe corrosion issue but can only find LHD pipes online.
Cheers
Lenny
x 63
Unread post by Lenny »
It might be worth a call to Steering Specialists in Wakefield.
If your pipe is corroded where it goes into the rack the I know they've got a fix for this.
aerodynamica
x 215
Lenny wrote: 05 Feb 2023, 20:30 It might be worth a call to Steering Specialists in Wakefield.
I'll second that. I have just had them recon my rack and replace the low pressure pipe end.
Graeme M
