Jay-Bruce
- x 280
It's just part B I am after; but I suspect the availability's not going to be any better? Still might be handy to have the part numbers so I can try and source some new old stock somewhere?
- x 6954
No part numbers for 'B' alone from Citroen, just the complete door card.
Jay-Bruce
- x 280
Ah! I understand now, thanks marc
seanrx
- x 6
Hi Marc.
I need some part nos for my alternator and its regulator please.
Vin: VF7**************[VIN obfuscated, can be read by forum staff]. C5 2.0L petrol.
- x 6954
Hi Sean
Altrernator
Item (1)
New Bosch Alternator (0 124 525 063) or (0 124 OAC 3PB) 150 Amp, part: 5705CA, £929.77
Reconditioned Bosch Alternator (Same Markings as Above) 150 Amp, part: 5705EK, £508.91
Regulator
Note the Regulator part marking is slightly different to the Bosch alternator listed above, but it's the only one listed for Bosch under your vehicle, so may not be correct - you will have to check with Bosch, as 0 124 525 035 is a different model alternator.
Item (4) Bosch Alternator Regulator (0 124 525 035), part: 5761C7, £227.38
Altrernator
Item (1)
Regulator
randomandy
In some quite spectacular driving I managed to pull off the black plastic strip on the outside of the rear passenger side of the 308 (VIN VF3**************[VIN obfuscated, can be read by forum staff]).
The plastic strip itself is fine, as is the door, and all the remaining paintwork I just need a replacement set of plastic clips as they have all got broken!
-Andy.
-Andy.
- x 8049
- x 6954
Item (75), part 856562, £6.01 (probably for a few).randomandy wrote: 05 Jan 2023, 17:43 In some quite spectacular driving I managed to pull off the black plastic strip on the outside of the rear passenger side of the 308 (VIN VF3**************[VIN obfuscated, can be read by forum staff]).
-Andy.
randomandy
Thanks Marc and Mick
wfdTamar
Hi. Part numbers for all spheres for a 2015 C5 X7 LE (2.2 litre 150kw). Not sure which are faulty so need numbers for all please).
VIN VF7**************[VIN obfuscated, can be read by forum staff]
2015 C5 Limited Edition (2.2 HDI) 150 kW 450Nm (Racechip S 179kW 528Nm)
- x 6954
Front Corner Spheres (inc. Gasket)
(2) OEM Original, part: 1638046780, £173.90
Citroen Cheaper Alternative, part: 1638378080, £83.52
Rear Corner Spheres (inc. Gasket)
(2) OEM Original, part: 1638045580, £173.90
Citroen Cheaper Alternative, part: 1638376780, £83.52
Front & Rear Rigidity Spheres
(3) Front Rigidity Sphere & Gasket
OEM part: 1638046580, £171.36
Citroen Cheaper Alternative, part: 1638377880, £87.73
(4) Rear Rigidity Sphere & Gasket
OEM part: 1638045180 (each), £173.90
Citroen Cheaper Alternative, part: 1638376280 (each), £78.44
All from Citroen direct (UK prices inc. 20% VAT).
Orbit Motors
- x 19
Afternoon,
After a few numbers for my 306, apologies for the slightly long list.
- All 3 pedal rubbers
- Clips that hold the exterior rubbing strips to the doors
- If it shows this, which braking system is fitted (caliper type and vented/solid etc) to front and rear
- With the above in mind, front discs and pads and rear drums and shoes.
- Thermostat housing (fuel filter mounted on top type)
Big thanks in advance
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
Miles
- x 6954
Pedal Covers
Accelerator Pedal Cover, part: 160410, £12.30
Brake Pedal Cover, part: 450412, £18.29
Clutch Pedal Cover, part: 213015, £14.84
Door Protector Clips
Door Protector Clips, part: 6995X3, £0.16p each
Front Brakes
Ventilated Front Discs, Rear Drums.
Front Calipers
Note: No longer Available from peugeot
Left OEM, part: 4400J4
Cheaper part: 441059
Right OEM, part: 4400J5
Cheaper part: 441060
Note OEM or Exchange Calipers no longer available from Peugeot directly.
Front Discs
OEM (DIAM 247 - EP 20,4), part: 424996, £186.04
Cheaper Discs, part: 1687773880, £62.00
Front pads
OEM, part: 425316, £91.40
Cheaper part: 1617252380, £20.59
Rear Drums
Note: There can be a either Girling or Bendix system fitted. So depends on what you have as either type may have been fitted.
Bendix
Note that the brake plate, the brake hub & Drum and OEM 4 shoe prefit kit (DIAM 180X30) are no longer available from Peugeot, only the cheaper 4 shoe kit which is part: E170063, £96.08.
Girling
Similarly, the brake plate, hub & Drum is no longer available.
Set of 4 brake shoes OEM, part: 4241E5, £45.02
OEM 4 shoe Prefit kit (DIAM 180X30) no longer available
Cheaper 4 shoe Prefit kit, part: E170034, £97.09
Complete Outlet Water Tank Housing, part: 1336L7 (No longer available), however there are some components of the housing available individually. You'll have to provide me with the item numbers for any that you are interested in.
Front Brakes
Front Calipers
Front Discs
Front pads
Rear Drums
Bendix
Girling
WindyMiller
Hello. After diagram/part number for lower universal joint on xantia VIN VF7**************[VIN obfuscated, can be read by forum staff]
Regards
Regards
- x 6954
@ Windy
Item (7) Ball Joint
OEM Original part: 364071, £95.11
Citroen Approved Alternative part: 1607295080, £18.98
(8) The Ball Joint Protector is no longer available from Citroen.
Item (7) Ball Joint
