2.0 HDi engine - Xantia
Rostami
Unread post by Rostami »
Hi to All,
The 2.0 HDi engine (DW10ATED - Xantia and Xsara) has two cylindrical parts that connect via vaccum tubes to the turbo. One of them connects to the wastegate I guess. Does anyone know what their function is?
Thanks,
Rostami.
Kowalski
Unread post by Kowalski »
Are they the electrovalves that control the wastegate?
Rostami
They are two valves, yes. Any Ideia how they work?
guillermo
Unread post by guillermo »
Dear all,
One of them controls the EGR valve, the other one controls the waste gate valve of the turbo.
They use vacumm from the vacumm pump in the extreme of the camshaft, and are electrically controlled by the ECU.
Regards
guillermo
miked
x 6
Unread post by miked »
have a look at the air supply and EGR sections of http://www.christiantena.pwp.blueyonder ... ioperation
Rostami
Thanks to all!
x 1044
Unread post by wheeler »
if its a 90bhp model one of them operates the EGR valve & the other operates the EGR throttle butterfly.If its a 110bhp there is a 3rd one that operates the turbo wastegate.
