Fuel temperature sensor and egr codes
Pete the painter
Unread post by Pete the painter »
Hello folks. Recently had overheating issues I came here got advised turns out it was faulty thermostat and that sorted that issue...but...I'm back again seeking yet more advice if possible.
It's a 1.6 hdi Berlingo van and I've got 8 error codes detected on scanner. 3 of the codes are aimed at the egr. Insufficient flow, control circuit and recirculation low
3 codes are aimed at the fuel temperature sensor, circuit A high..
Can anyone advise where the fuel temperature sensor is located and what it looks like. I have an idea where the egr is found back right side under fuel filter.?
As a complete amateur when it comes to engines any other advice what steps I could take to diagnose and where to start would be gratefully appreciated.
x 1432
Re: Fuel temperature sensor and egr codes
Is the engine management light on? If you clear the codes do they come back?
