My ds5
Starts and drives fine at steady driving if you put you’re foot down the engine light comes on with these codes
P1ad9
P1a79
P1ac4
P0a35
Any help please are they connect?
DS5 Fault Codes
- x 6958
Re: DS5 Fault Codes
These do not appear to be valid fault codes.
Yadida78
Re: DS5 Fault Codes
These are the ones my mechanic gave me I will double check
arcadiecvas
Re: DS5 Fault Codes
My DC5 started but it lasted a second- the engine stopped abruptly. A warning message would apprear on screen - something like faulty engine- PLEASE REPAIR THE ENGINE.
The electrician fixed it and it drove nicely. However rare messages of faulty engine appeared again. after 400-500km the car broke down again with the same symptoms. Another electrician removed the inverter and checked it throroughly. Having diagnosed it he got the following error codes:
https://usait.x431.com/Home/Report/repo ... imezone/+3
I was adiced to get another inverter. Now the issue is how I get a compatible inverter, as I cannot find with similar codes (I mean the ones written on the body of the invertor).
