Citroen C8 (2008) clutch master cylinder reservoir
Klepto
Unread post by Klepto »
Hi all,
Wonder if anyone would be kind enough as to tell me where this is? Having a bit of trouble finding it, dropped the air filter bit down and can see the brake one, but can't see a separate one for the clutch anywhere.
Many thanks
Klepto
x 2184
Re: Citroen C8 (2008) clutch master cylinder reservoir
Unread post by MattBLancs »
Is there definitely a dedicated reservoir?
Clutch just takes a feed from the brake master cylinder on both my 406 coupe and Citroen C5 (and my wife's 206 too)
Some earlier 406's didn't take a feed like this but master, slave and connecting pipework were a sealed system on those.
Klepto
That very may well be the reason I cannot find it. Clutch has been having issues this past week and I wanted to double check in case it was as simple as a fluid top up.
Klepto
Thank you.
