Chinese Android Multimedia Panel on Peugeot 206 not working properly
This section is for General Enquiries or for Systems not Covered Above
x 6950
Re: Chinese Android Multimedia Panel on Peugeot 206 not working properly
GiveMeABreak wrote: 22 Nov 2022, 11:12 Ok, as I thought, you have a Mercosur vehicle and these are often configured differently. I can't help you as the it just states radio without speakers and does not list the equipment, so I won't be able to match up the wiring to a diagram for the pinouts. The pictures you provided are useless to me as the wiring diagram is needed. The colours of the wires are also no good as PSA change the wiring frequently. Without the electrical diagram I can't help you determine which pin does what.
I may have some basic info - but I have to go out now, so I'll update this post later if I find it.
Ok so here is the diagram for your vehicle - it shows the connections for the basic Audio system and as you can see there are multiplexed connections as I mentioned. So you now what the pins are for and need to ensure you have a compatible harness for your Android unit.
8410 Audio System
BSI1: BSI (Main Vehicle Computer)
Wires
MC30R : earth mc30
BE11 : BSI battery + output
CE : BSI + after ignition output
XE : comfort VAN +
9005 : Comfort Van data bus B
9004 : Comfort Van data bus /
UserFromInternet
Unread post by UserFromInternet »
Ross_K wrote: 22 Nov 2022, 18:09
On the cable going in the back of your radio, you need to find the "ignition" 12V wire (use a multimeter to figure out which this is), cut it and solder in the feed from the lighter.
You probably don't want to cut the factory-installed wire, so buy a sacrificial ISO -> ISO adapter cable and cut that instead:
I'm gonna check that out, pal. But, is there any way to fix the cord if it is broken as you explain?
UserFromInternet
GiveMeABreak wrote: 22 Nov 2022, 18:18
8410 Audio System
Wires
MC30R : earth mc30
XE : comfort VAN +
Thanks for helping me, pal!. You're awesome :).
What should i check? i'm kinda lost
UserFromInternet
8410 Audio System
Wires
MC30R : earth mc30
XE : comfort VAN +
I have these 2 plugs from the car i have attached an image).
What should i do in order to "verify" what you told me?
x 1057
Unread post by wheeler »
Do you have a wiring diagram for the Android unit? and a link to the unit you bought?
UserFromInternet
wheeler wrote: 22 Nov 2022, 22:01 Do you have a wiring diagram for the Android unit? and a link to the unit you bought?
I don't have the wiring diagram but i already asked for it to the seller.
Take a look at these images (based on the diagram upload in this thread). What do you think?
x 6950
UserFromInternet wrote: 24 Nov 2022, 12:25
GiveMeABreak wrote: 23 Nov 2022, 15:35 I'm not sure what else I can do to help you further - you need to contact the supplier with the pin designations on the connector they have supplied you.
Your existing connector will have wiring codes on the wiring sheaths. Look at my wiring diagram in the main forum and you should see these matching up - which will tell you which wire is on which pin.
Pal, the seller sent me this diagram from the Android Multimedia Panel
Well that Android unit doesn't seem to have any multiplexed connections at all. Your factory system was supplied without speakers, so even if you can even get this to work, you can forget about any fancy features working.
x 1057
The other issue you have even if the android radio is CAN compatible is that your original radio is on a VAN network, the 206 never used a CAN radio.
VAN is a PSA specific protocol.
UserFromInternet
Just came to say it worked for me!. I used a piggyback fuse :)
x 5679
Useful!
Bought a dashcam for my granddaughter who passed her test a couple of weeks ago and may hardwire it in this manner.
