Peugeot 207 CC 1.6 Vti no response from turning key to start position
gwest
x 20
Unread post by gwest »
I sold my 2007 207CC Vti 1.6 auto with 134,000 km on the clock earlier this year to a young student. In my defence I should add that I did everything possible to ensure the engine would be reliable! It had an engine transplant from an XT with 100,000 km on the clock, with new piston rings and valve seals fitted- the cylinder head had a total rebuild. It also had most of its rubber seals/ O-rings replaced as well as new plastic bits like the thermostat, expansion tank and coolant pipes. It ran very nicely and I was quite impressed with its performance. I did about 4,000 km on it before I sold it, looking for a new retirement project.
Today I received a call from the new owner to say that when she started it this morning it ran very badly and had a depollution system faulty warning. Then the engine stopped.
I was surprised to find that while the ignition switched on as normal and the instruments and dashboard lights came on when you turned the key to the start position there was absolutely no response. No solenoid clicks - no turning over. The battery voltage was around 12.0. My Launch diagnostic reader could not connect to the ECU. It read the other modules ok. And previously when I owned the car it read the engine ECU ok and gave similar results to Diagbox. We tried her spare key fob and it made no difference.
The only adverse recent events were that she had hit a kerb sufficiently hard to bend the LHS front steel rim. It had also been using a small amount of coolant, although there were some signs of splashes around the fan housing that might explain that. The battery connections looked fine as did the multi-plugs into the ECU looked secure, but I did not remove the plugs. The oil level was also ok.
I'm no electrician and I don't have any wiring diagrams anyway. And I am hesitant to probe around on a live system in case I do damage. With no communication with the ECU my first thought was that maybe it was an ECU problem. But I gather that problems with the relays in the under-bonnet fusebox/BSM are more common. I have spares of both of these from the 2007 XT Vti manual that donated its engine. They don't have identical part numbers but I was wondering if they might be useful for diagnostic purposes if I tried fitting them. I would check that the XT box had fuses in the same places as the CC, and I realise that with the ECUs that the car would not start because of the immobiliser codes, but that at least the starter motor might turn over?
BSM. CC auto: 9661708280, BSM L11-00. XT manual: 9661708180, BSM L10-00.
ECUCC auto: 9663193580, XT manual 9663193580.
Any advice on how to proceed would be most welcome. I am reminded at home that I am under no obligation to assist, and it doesn't help that the new owner is young and pretty. This may not end well!
gwest
x 20
Re: Peugeot 207 CC 1.6 Vti no response from turning key to start position
I should have added the following information.
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Diagnostic troubles codes: Launch 123. All faults are permanent.
Automatic gearbox. 0026: Accelerator pedal position not characterised.
ABS U1308:Engine ECU operating fault. Not characterised.
U1108: Communication missing fault with engine ECU no signal
Power steering: U1108 Fault engine status information. Not characterised
U 1308 Fault engine status information. Not characterised.
x 1484
Do you have dialogue with the engine ECU? Does the EML come on at key on? My first thought is that the ECU has lost power or ground (or it's toast!).
gwest
x 20
Richard there was no dialogue with the engine ECU. Today I returned to the car thinking that maybe her slight offroad excursion had broken some electronic component or a wire in the loom. This time I sat behind the wheel. Ignition came on but the battery icon was flashing. To my surprise it started, although it ran very badly for a while - I am assuming that the ECU had to relearn the optimal settings. The GPS HUD (not connected to the OBD port) voltage display took a while to come up to 14.4 so the charging circuit is ok. The battery is new so hopefully all that is required is for the owner to drive it a bit more. Being parked in the street limits her options for charging it from the mains.
