hi guys. what type of oil is good to use in engine break-in period?
engine is Xu10j4r
and i just finished engine overhaul and everything is in minimum factory clearance range including crankshaft bearings clearance and cylinder wall to piston clearance.
can i use normal SAE30 or SAE40 normal mineral oil for first 20 min run?
xantia xu10j4r engine break-in oil
OnlineCitroJim
- x 8462
Re: xantia xu10j4r engine break-in oil
I'd just use your normal, preferred oil and then drain after your initial run, change the filter and refill...
I don't believe running-in (break-in) oil has been used for years now...
saeedm
- x 16
normally i use synthetic or semi-synthetic oil
But synthetic oils seem to glaze cylinder wall cross hatch.
+ i have used MAHLE pistons and rings and im sure that they will not be as good as OEM ones
i kinda dont want to mess it up, i want go careful
OnlineCitroJim
- x 8462
In that case, initially use a good quality mineral oil...
