TheWizard
- (Donor 2026)
- x 3
Hi Admin,
My first post, so apologies for any faux pas.
I need the part number for this thingy (in line filter perhaps?) Not sure what to call it. But it's located in the LDS line, above and aft of the fuel tank. It seems to encase the union of the LDS line (which presumably runs from the BHI in the engine bay) with the LDS line that takes the fluid to the rear struts. It's weeping and needs replacing.
Thank you
Please see very short video and pics below to help you identify this part:
https://files.fm/u/j7d96m4w5
https://ibb.co/kM3mGwg
https://ibb.co/DWSzkh9
Thank you
- x 6946
Supply Piping Rear Suspension
Item (2) Hydraulic Pipe 2-Way Union possibly? If so, part: 5280R3, £10.82
Here are the other pipes for the suspension.
Return Piping Rear
If anything else, let me know.
Return Piping Rear
TheWizard
- (Donor 2026)
- x 3
Hi Marc,
Much appreciated. This looks to be the "thingy" that I'm after. I thought it looked like a union of some sort.
Would I be right in thinking that the pipes simply push fit into this, one at each end? No special tools needed?
From the diagram it looks like the pipe ends are fluted and have "O" rings on them.
TheWizard
- (Donor 2026)
- x 3
Just thinking out loud here; the union is weeping, ergo the seals have perished. So, whatever the fitting method (push fit or threaded) I will require new seals for the pipe ends. Is there a part number for these?
Or as the only purpose of part 5280R3 is joining the two pipes, perhaps I could simply square off the ends and connect using high tensile, chemical resistant flexible tubing and secure with hose clips.
dylan26__
- x 22
looking for the little plastic connector / socket thing for the vacuum pump please.
im sure if i see the diagram i can elaborate more on what i mean. VF7**************[VIN obfuscated, can be read by forum staff]
- x 6946
Brake Vacuum Pump
If this is what you are referring to - your description is a bit vague. Let me know the item numbers.
dylan26__
- x 22
sorry for being vauge i didnt know how to describe it! it is the right hose connector on the pump. doesn't seem to be numbered though.GiveMeABreak wrote: 14 Nov 2022, 11:19 Brake Vacuum Pump
- x 6946
Ok, so the hose is shown on the brake Servo diagram below:
The Brake Vacuum Hose is item (6), part 4578N4, £35.59
However, the connector is not sold separately and is attached to the pump:
The pump (1) is part: 9804021880, £166.73
All prices VAT inclusive direct from Citroen.
dylan26__
- x 22
perfect, thank you once again Marc!
Beepbeep
Good morning Marc,
would you be able to advise me what gearbox codes would fit my 04 plate 206 1.1 fever please?
My VIN Number is VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks
Many thanks
- x 6946
Here you go:
Item (1) Gearbox New, part: 2222S6 (No longer Available)
CP(14X60) CT(19X17)
MARKING CP08 CP80 (CP80) CF08
Standard Exchange Gearbox, part: 2223WV
CP(14X60)-CT(19X17)
MARKING (CPK8) CPK8 CP08, £1,695.02
CP(14X60) CT(19X17)
CP(14X60)-CT(19X17)
Beepbeep
Thanks Marc for the swift response.
Sorry for the rookie question here, but am I right in thinking a salvaged box with the gearbox code 20CP80 would fit and will have the correct ratios?
- x 6946
It should, as these gearbox housings were modified from August 2003, so the new components Id's begin 20CP.
ekaftan
- x 8
Hi,
What brake pads should my car use? Local seller wants to sell me ones that every google search I have made lists as one for 2008 on and my car is 2006.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Many thanks.
- x 6946
@ ekaftan
Fronts:
Item (3) OEM Original, part: 425289, £115.61
Citroen Cheaper, part: 1617274180, £48.47
Rears:
Item (3) (OEM Original, part: 425334, £103.15
Citroen Cheaper, part: 1617257280, £22.93
Fronts:
Rears:
