dylan26__
x 22
Unread post by dylan26__ »
GiveMeABreak wrote: 06 Nov 2022, 15:39 If it's the door seals:
(4) Door Entry Seal, part: 9025Z7, £114.72
(5) Drip Moulding Seal, part: 9025Z8, £54.48
Sorry i meant on the door itself around the glass. unless (5) is that part?
x 6947
The only other parts are the following for the window:
(4) Left Door Window Lower Outside Seal, part: 9309S5, £62.04
(6) Left Door Windows Lower Internal Weatherstrip, part: 9309S7, £30.10
Huskyxantia
x 927
Unread post by Huskyxantia »
Hi marc, is this a 206 seal ? Cheers.
:-D
x 6947
No, it's for 'dylan26__'s DS3
dylan26__
x 22
GiveMeABreak wrote: 06 Nov 2022, 16:06 The only other parts are the following for the window:
Perfect, Thanks again Marc!
x 8148
Marc could you tell me the part number for the driver's side outside lower window seal as pictured at number 4 but for my fleet Citroen C4 Picasso please. The VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Thanks in advance
M
x 6947
Hi Mick
Item (5) in your case, Door Window Outer Lower Seal
Right Side, part: 9334P8, £97.45
x 8148
That's a tenth of what the car is worth so I shall have to devise a stick on squeegee blade type device to at least improve it. The door had 4" of water in it when I set about cleaning the scuttle drains which were not blocked at all. The swishing must have been from the doors!! Thanks Marc :)
dave101ua
Unread post by dave101ua »
Hello
what is the official number part of the oil filter please? (I want to change oil in engine and change filter as well)
C4 Grand picasso 2017, bluehdi 2.0
Thank you
x 6947
@ dave101ua
Item (2)
Original OEM Filter, part: 1109AL,
Cheaper filter, part: E149134
jordyh
x 4
Unread post by jordyh »
GiveMeABreak wrote: 02 Oct 2022, 21:55 Image
Item (1)
OEM part: 16 463 470 80, £1798,.74
Exchange Part: 16 741 387 80, £1755.89
Hi Marc,
Could you please give me the part number for item 11 and also the locking nut that attaches the steering column to the rack please?
B78 Picasso VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks!
x 6947
@jordyh
Steering Rack
Item (11) MUL Self-Locking Nut (M14 X 150), part: 362271, £2.21
Steering Column
(5) Steering Universal Joint Bolt (DIAM 8X125-35), part: 410562, £2.52
(71) MUL Self-Locking Nut (8 X 125), part: 6939C2, £0.37
Huskyxantia
x 927
Morning Marc, have you part numbers for 206cc hand brake cables left & right, cheers.
:-D
x 6947
Here you go:
There are possibly 2 types shown as:
Item (3)
Brake cable part: E074094, £24.18
Secondary Brake Cable (LONG 1725) 4745N5, £69.97
So check the lengths of existing.
PS I'm off out for the next few hours, so if anything else is needed I'll deal with it on my return.👍
Huskyxantia
x 927
Cheers marc, ill measure mine then ill know what should be.
:-D
