Climate Control Unit problem
goldengate
Unread post by goldengate »
Hello,
I have Citroën C4 1.6 HDI 2013.
Suddenly one morning when I started engine, on Climate control buttons appeared Fahrenheit instead of Celsius degrees. How to return back Celsius degrees on buttons?
Has anyone had a similar experience?
Thanks.
x 6950
Re: Climate Control Unit problem
Go into the settings menu (usually via the radio) and reconfigure it there under 'units', where you should also see distance units too.
goldengate
Problem solved: when you start engine just press two buttons together: A/C and button to recirculate the interior air( above A/C button).
goldengate
Re: Tire pressure not recognized
My car doesn't recognize low air in tires. And display shows "OK'' near all wheels all the time.
Please advise where could be a problem.
