x 6955
Huskyxantia wrote: 16 Oct 2022, 19:17 Hi marc, have you the part number for 206cc boot struts , my boots getting heavy to lift ,it stays up but is a bit heavier since last year so there on there way out , many thanks
Here you go:
Item (20)
OEM Original, part: 8731F2, £66.11
Peugeot Cheaper part: 1615074280, £27.40
Huskyxantia
x 879
Unread post by Huskyxantia »
Nice one , cheers marc
:-D
Huskyxantia
x 879
Hi marc , I'm looking for a 2 piece exhaust clamp for the back box ,,for my 206cc, i didn't realise there were lots of sizes I'm getting 55mm to 80mm. 8m guessing 65mm ? But I'm wanting to be right, could i have the part number please, many thanks
:-D
x 6955
It's 66mm Diameter.
Item (4), Part: 171366, £10.63
Huskyxantia
x 879
Thanks marc, is item number 2 the same as number 4?
:-D
x 6955
It is. Item 2 it the original part number as I quoted above, but item (4)was a different part number, now replaced with the same, so 171366 for both part numbers.
Huskyxantia
x 879
Think its time for a crankshaft pulley for my 307sw 2.0hdi, could i have the part number please marc,many thanks.
:-D
NotAnInterestingName
(Donor 2022)
x 51
Unread post by NotAnInterestingName »
Hello. Please let me know the part numbers of the AdBlue injector and sensor(s) that may be relevant to this issue...
viewtopic.php?t=72726
Car is a DS-brand DS5, VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
x 6955
@ NotAnInterestingName
I've put the pipe and harness up in case, but the tank shouldn't need these unless they are also faulty.
(3) Additve Reservoir, part: 9816296080, £252.72
(36) Additive Supply Pipe, part: 9802991980, £47.39
(37) Particle Filter Harness, part: 9803525780, £41.42
Huskyxantia
x 879
Huskyxantia wrote: 19 Oct 2022, 21:41 Think its time for a crankshaft pulley for my 307sw 2.0hdi, could i have the part number please marc,many thanks.
Marc is there 2 types of these pulleys ? Im seeing a solid one and one with holes in ?
:-D
x 1056
Unread post by wheeler »
GiveMeABreak wrote: 24 Oct 2022, 15:36 @ NotAnInterestingName
Unless i've missed something the OP is asking for parts of the adblue system not the DPF additive??
(Donor 2022)
x 51
Yes, AdBlue thanks. But I'll still keep a copy of the DPF system too as I'm bound to need bits for that during my ownership!
Many thanks to you both, vastly appreciated. Found the injector, I'll probably just get that replaced anyway if it's in doubt, it would cost less in labour to replace both at once than to do one at a time.
Is there a specific sensor for the AdBlue system? I can't see one on the diagrams/lists. I'm looking for whatever sensor said it had a "NOx content upstream of the deNOx catalytic converter" value that was off the scale.
Cheers
x 6955
Oops, I was dealing with a DPF Tank issue just previously, so was on the brain. I think you have everything you need now.
x 6955
You can have either a single or double damping pulley, so here are both parts:
(7) Double Damping Pulley (DIAM 162X30 EP 37 6V), Part: 0515V6, £288.24
(7) Single Damping Pulley (DIAM 158 EP 36,8 6V), Part: 0515S4, £226.48
Flywheel in case you need that:
(12) 0532H8 £581.75
(Donor 2022)
x 51
GiveMeABreak wrote: 24 Oct 2022, 21:02 Oops, I was dealing with a DPF Tank issue just previously, so was on the brain. I think you have everything you need now.
No probs, I'm always grateful!
Do you know where the upstream sensor is? I can't find it on any diagrams. I'm wondering if it's fitted upstream of the injector, or perhaps it's shown somewhere and I've missed it.
