P2686 fault code what does it mean ?
Huskyxantia
x 926
Re: P2686 fault code what does it mean ?
Unread post by Huskyxantia »
Hope the weather stays kind for your weekend of reworking your wiring ! Post the results after very keen on your results.
:-D
KennyW
x 165
Unread post by KennyW »
Finally success, sorted the wiring issue.
Yet again I managed to mix up the wires. But fortunately I did something good. I ordered wiring of the same colour as in the harness and connected them together. So I only had to move the spade terminals into the correct order so I have continuity.
Waiting for battery to charge fully before attempting to start her up.
I did notice a tiny crack in the camshaft sensor so replaced it with new Delphi brand, likewise replaced Crankshaft sensor with new Febi brand..
Question re new sensors fitted will the ECU's recognise same or do I have to use the Diagbox for this ?
Kenny
C3 1.4 petrol (SWMBO)
Huskyxantia
x 926
The new sensor we be ok, I've replaced one of mine with an after market type it started ok it , good to hear that you have the winning line in sight. =D>
:-D
x 8423
One thing to watch out for when soldering is that where the solder alloys with the underlying copper wire it can become very brittle and over time can break and go open-circuit in areas of high vibration...
Also, the heat shrinking must be very good to prevent any risk of moisture ingress else corrosion will develop and rot the joint - a common problem still on Xantia wiring harnesses that used soldered splices...
Wago connectors are good but similarly will need very careful moisture proofing...
I still favour a good crimped straight joiner... They must be correctly sized and properly crimped using a high-quality tool. The cheap, flat crimp tools usually supplied in crimp kits are absolutely useless...
x 5675
It increases the complexity, the cost and the size of the joint but Wago have a range of moisture-proof enclosures that will hold several connectors.
Probably over the top for this sort of job and probably too bulky as well.
I have done soldering and crimps in the footwell and it was no fun at all.
I had something I wanted crimping recently. I should have hundreds of them that came with the professional crimping tool I replaced the crap on with.
Naturally, couldn't find them and resorted to solder and heat shrink.
This was before I bought any Wago and Ideal connectors.
KennyW
x 165
Thanks for the replies Nice to hear from you Jim. Hope all is well.
Kenny
x 8423
KennyW wrote: 13 Oct 2022, 16:11 Nice to hear from you Jim. Hope all is well.
Happily, very well indeed Kenny and I trust you are too :-D
