cs101
- x 6
Hi
"Electric Pump Item (1), 1679831980, £905.89"
On Ebay the part number they have is 9818127580. Is this the old part number which matches this electric pump?
Thanks.
Thanks.
- x 6957
That's not a Peugeot part number. The number I gave you has not been revised, and is the same from 2016 to date, with your build date being June 2018 so is the original part number. Unfortunately I can only help you with official part numbers, but be wary of ebay databases as they can be notoriously wrong or for the wrong vehicle. If you can provide me with a link I'll see if I can advise further.
cs101
- x 6
Thanks Marc, please check item 115144209834 on EBay.
https://www.ebay.co.uk/itm/115144209834 ... BMxsHAm_Zg
- x 6957
That may be a manufacturer / internal reference. Having checked all possible options for your RHD van there are 10 possible Power Steering Modules and these all have different part numbers, based on suspension type, subframe type, wheels, wheelbase, build date, etc. etc. As they all look identical, you will be taking a chance and I cannot confirm that the item in your link is correct. The ECU will be specifically configured for your VAN type, so you need to consider that too.cs101 wrote: 07 Oct 2022, 05:57 Thanks Marc, please check item 115144209834 on EBay.
If possible, it may be worth cross referencing the labels from your old PS unit and using this as a reference to match any you find - but other than that I can't help. Recoding an ECU on a van of this year is likely a dealer operation, as the ECU will likely be secured requiring a correct later version of Diagbox (likely V 9.**), a dealer-level diagnostic tool, suitable laptop, and purchased tokens for configuring. That's why it's important to get the correct one to start with as it will be configured for your specific vehicle.
cs101
- x 6
Thanks, Marc.
randomandy
Could I have some part numbers for a Peugeot RCZ (2010 1.6 petrol) please? First up, it needs front mats as they are missing!
Also, the high level brake light is missing some bulbs. Are these individually replaceable or does the whole assembly need swapping? If the latter, could I have the part number for that too please?
-Andy.
-Andy.
- x 6957
Andy - I will need the VIN for this vehicle first then I can advise on the high level brake light type.
As for the mats - are you looking for Peugeot custom fir accessory mats? They are usually several versions available depending on what you want, but I'll be able to advise when I have the VIN.
randomandy
Thanks Marc
The VIN is VF3**************[VIN obfuscated, can be read by forum staff] (assuming it is the number visible at the bottom of the windscreen the same as the others)
For the mats, I'm looking for whatever was factory fit.
-Andy.
-Andy.
- x 6957
One thing of note, your RCZ is being flagged up with an outstanding after-sales campaign. So I would contact the dealer, provide the VIN or registration and they will be able to tell you what it is for. It should be free of charge.
Ok, so the rear supplementary brake light is a complete unit and as per the manual, the bulbs are not sold separately on parts, as they are diodes and it states refer to the dealer. In case you are wondering the
complete unit is part: 6350KE, priced at £206.78.
Mats
2 Choices for the front:
Rubber Part: 9464GE, £72.40
Velour Part: 9464GV, £77.77
Mats
- Without logo.
- Reinforced heel mat area.
- NR/SBR rubber.
- Set of 2 front mats in black tufted velours.
- The carpet mat on the driver’s side bears the RCZ logo on a metal plate.
- Double anti-slide safeguard provided by an anti-slip sub-layer with fixing system.
- Carefully finished with original design.
- Appreciably adds to the sound and heat proofing, as well as lending something to the aestetics.
- Density of 800 gr/m².
- Nubuck piping with black stitching.
- All the RCZ mats feature fastenings on both the driver’s side and the front passenger’s side.
- Set of 2 rear carpets in high density tufted velours, black.
Huskyxantia
- x 906
Hi Marc, needing part number for the oil dip stick for my 206cc
Also how does this display work out how much oil is in the engine , that square box thing when you start the car.
Husky.
- x 6957
@Husky:
Item (10) Dipstick, part: 1174G2, £22.43
Some vehicles are fitted with an oil temperature and level sensor, but even in such cases, the official recommendation is always to use the dipstick to check oil level and never rely on the dashboard level display alone.
Huskyxantia
- x 906
Top work marc many thanks.
Husky.
thatpretorianguy
Hi,
Looking for a part number if anyone can help.
2010 Citroen C3 II SC 1.6 HDi 68kw 92ps, my partners car the coil spring at the rear on the right has come out of place(probably due to my driving as I have a Tesla Model 3 and drive the citroen as if its also the same performance
) so what I like to do usually when sorting stuff since I'm doing all the work anyway is upgrade things, usually I have to fight her on this but I've managed to wangle a headlight upgrade past her so far, new osram bulbs, and a full brembo disc and pad upgrade on one axle.
What I'm secretly doing now is a full bilstein rear damper upgrade, new coil springs, new dampers, and I can find the upper rubber stop on the coil spring but for the life of me I can't find the lower rubber seat?? I've even gone direct to Febi website(they make the upper rubber stop I'm going to get) and still nothing
Part 6 on the attached diagram.
Huskyxantia
- x 906
Hi marc, have you the part number for 206cc boot struts , my boots getting heavy to lift ,it stays up but is a bit heavier since last year so there on there way out , many thanks
Husky.
- x 6957
Please refer to the first post on this thread.
