99xantia
(Donor 2022)
Unread post by 99xantia »
GiveMeABreak wrote: 21 Sep 2022, 17:09 It doesn't work!
Just save the image on your PC and upload it as an attachment please.
OK, done that. Very odd. I've used the original method to share images on this and other forums before. Not sure why it hasn't worked this time.
Looking for the metal parts above and below subframe in this pic (not the plastic holder or brake pipe/sensor).
Thank you.
x 6956
This is what is shown:
Let me know which bits (if any) you need part numbers for.
x 5671
That isn't working, you may have it set as private.
To upload direct to the forum, have a look at this guide
99xantia
(Donor 2022)
GiveMeABreak wrote: 21 Sep 2022, 17:55 This is what is shown:
Excellent. Thank you so much.
I guess 4, 5 2, 6 & 70.
dulenator
x 11
Unread post by dulenator »
Hi!
After many days of "offline" searching, I didn't find the correct part.
Can you please tell me the part number for the right-side drive shaft?
x 6956
Here you are:
OEM Original Right Driveshaft, Part: 3273RN, £555,43
OEM Exchange Right Driveshaft Part: 3273NV, £327,14
dulenator
x 11
Great! Thank you! :bd:
cs101
x 6
Unread post by cs101 »
Please can I get the following part number for my van. VIN VF3**************[VIN obfuscated, can be read by forum staff].
1.Front complete Bumper without fog lights.
2. Front Nearside Wing Panel.
3. Steering Reservoir (Where the steering fluid goes)
Thanks.
Ohfishalee
(Donor 2022)
x 7
Unread post by Ohfishalee »
Hello, I am looking for schematic for a Lucas (?) fuel injection pump - specifically wondering of there is a seal that can be replaced (mystery air lock has occured. all pipes checked and no leakage).
Veh Type - Peugeot Partner Van 2006
Suspect injector pump but unsure if it has replaceable seals to mate pump to engine.
x 6956
cs101 wrote: 24 Sep 2022, 15:19 Please can I get the following part number for my van. VIN VF3**************[VIN obfuscated, can be read by forum staff].
Thanks.
Bumper
If you require any other item, just let me know the number from the diagram.
Item (1) part: 1615649280, £623.92
Wing
Item (1), Part: 9808757880, £385.88
Power Steering
Electric Pump Item (1), 1679831980, £905.89
It appears the reservoir is integral to the Power Steering Electric Pump.
x 6956
Ohfishalee wrote: 24 Sep 2022, 15:26 Hello, I am looking for schematic for a Lucas (?) fuel injection pump - specifically wondering of there is a seal that can be replaced (mystery air lock has occured. all pipes checked and no leakage).
Here are 2 diagrams, let me know if you want any specific part number from each as there are lots of components. Just specify Table A or B and the item you require a part number for:
Injection Pump Table A
Injection Pump Electropump Detail Table B
cs101
x 6
Thanks, marc
x 1067
Unread post by Rp0thejester »
Hello, what power steering fluid do I need for my C8? VF7**************[VIN obfuscated, can be read by forum staff]. Thanks in advance.
x 6956
You need TOTAL (AT42) Fluid for your Power Steering with mechanical pump.
Huskyxantia
x 901
Unread post by Huskyxantia »
Hi marc ,part numbers and whats included for injector seal kit ( if there is such a thing ) for my 206cc looks like gearbox end one is leaking . Cheers.
:-D
