moizeau
x 423
Unread post by moizeau »
Pete
x 6945
Here you go Pete:
Item (3) Steering Rod
OEM Part: 3812E7, £58.18
Cheaper PSA Version Part: 1682734780, £15.76
Item (5) Ball Joint Kit
OEM (Left), Part: 381765, £104.65
OEM (Right), Part: 381766, £104.65
PSA Alternative (Left), Part: 1682735780, £30.90
PSA Alternative (Right), Part: 1682735680, £30.90
(The cheaper alternatives are from Eurorepar)
moizeau
x 423
Thanks very much indeed. It's no. 3.
Pete
wesacosa
(Donor 2021)
x 3
Unread post by wesacosa »
Hi. I am after the part number for the injector leak off pipes for 1997 XM 2.1 TD XUD11BTE please
Cheers
x 6945
Here you go:
Item (2) Leak Back Pipe (CL 3X7-1000), Part: 156494, £17.41 inc. VAT.
wesacosa
(Donor 2021)
x 3
lovely. thank you
ekaftan
x 8
Unread post by ekaftan »
Hi!
I need to check if my car has the correct fuel pump.
Can you tell me what the correct fuel pump assembly is for VF7**************[VIN obfuscated, can be read by forum staff] ?
Thanks!
x 1052
Unread post by wheeler »
wesacosa wrote: 19 Sep 2022, 15:22 Hi. I am after the part number for the injector leak off pipes for 1997 XM 2.1 TD XUD11BTE please
Cheers
You can buy a metre of this on ebay or from any motor factors for under £4.
The kits even come with a blank for the end injector.
x 6945
ekaftan wrote: 20 Sep 2022, 02:00 Hi!
Thanks!
I'm assuming you are referring to the in-tank fuel pump and gauge? If so, as said it is both a pump and gauge module:
Item (2)
The part number is: 1611118380
ekaftan
x 8
GiveMeABreak wrote: 20 Sep 2022, 11:05
Can you tell me what the correct fuel pump assembly is for VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] ?
Thanks!
Item (2)
Thats it. Thanks!!
Side note, my car has one that looks like this installed... the side is flat and it feels like its not going in all the way into the tank. Maybe its for the wrong car?
x 6945
I obviously can't comment on the part you have currently (as it could of been previously replaced with an incorrect / aftermarket part), but the part number and info I have given you is correct for your vehicle.
ekaftan
x 8
GiveMeABreak wrote: 20 Sep 2022, 14:38 I obviously can't comment on the part you have currently (as it could of been previously replaced with an incorrect / aftermarket part), but the part number and info I have given you is correct for your vehicle.
I also think the part in the car is not the one that should be.
Thanks again!
99xantia
(Donor 2022)
Unread post by 99xantia »
Hello
Could anyone correctly identify this mount above and below frame please on a 1993 ZX 1.9D? (please ignore the mess, work ongoing!)
Assumed a 'subframe mount' perhaps but they look nothing like this.
The only thing I have found close what it looks like is listed as an 'engine mount'. This is just looking like the top part, above the frame.
https://www.ebay.co.uk/itm/292122600034 ... AFWD+--+N2
Many thanks.
Reason: Removed invalid image link
x 6945
Please attach your image to the Forum directly using the picture upload facility available with the Full Post Editor. The link you posted is not accessible.
99xantia
(Donor 2022)
Hi
Apologies. That is the same format I used and it was visible to myself.
Thank you.
This is via full editor:
https://lh3.googleusercontent.com/hmzlc ... authuser=0
