Xantia 1.9SD longer 5th gear
janssensalex10
Unread post by janssensalex10 »
Hi everyone
I recently got a Xantia 1.9 SD, absolutely love it but the only issue i have is 3400 rpms at 120 kph on the motorway. When i drive in the Netherlands it goes to 3800 at 130 kmh. Now, i read that the gearbox is the same as the 1.9D NA diesel engine. I want to swap it out for a longer one, but i am not sure which cogs i should get. The longer ratio will be no issue because it has 90 hp now instead of 75
I want to get the revs down to 2500 at 120 kmh
Does anyone have an idea?
janssensalex10
Re: Xantia 1.9SD longer 5th gear
Nice no one gives s damn 😂
x 5674
More likely that no one who knows has seen your post.
x 1470
Unread post by xantia_v6 »
