x 6946
The official PSA part number for your gearbox is: 2222TR (no longer available new).
CP 13X59
MARKING CQ27
An exchange gearbox is part: 2223ZY or part 2223ZZ with marking CQ27 or (CQBG)
So Google 2222TR and you will find plenty of options.
ninulus
(Donor 2022)
Unread post by ninulus »
So only CQ27.... I was afraid that's the only one. I can't find one like this in the entire UK, only in Germany and ind Holland, but it will cost me close to 800 pounds for a used one. And the original part from Peugeot, they quoted me 2000 pounds...
I guess the only solution is to scrap the car and get another one....
Thank you.
Ohfishalee
(Donor 2022)
x 7
Unread post by Ohfishalee »
What do the codes on the right refer to:
....."after/until/since OPR 12345"........
Trying to select correct rear shock absorbers for VF3**************[VIN obfuscated, can be read by forum staff]
x 1493
It's the date of manufacture, shown on a label on the driver's side B pillar.
Edit: From the VIN, yours is 10538, which means it was built on 15/09/2005
x 6946
Ohfishalee wrote: 23 Aug 2022, 01:19 Trying to select correct rear shock absorbers for VF3**************[VIN obfuscated, can be read by forum staff]
Just put your request here, we'll tell you what you need.
Item (1) Rear Damper
OEM Original, part: 5206SX, £66.06 each
Cheaper Alternative, Part: 1623313380, £44.05 each
All VAT inclusive from Peugeot.
eurofjr
(Donor 2022)
x 4
Unread post by eurofjr »
Hope everyone is having a good week. Almost the weekend!
VIN VF7**************[VIN obfuscated, can be read by forum staff]
I'm looking for PNs for the serpentine belt/accessory belt and the tensioner.
Best,
Jim.
Ohfishalee
(Donor 2022)
x 7
GiveMeABreak wrote: 23 Aug 2022, 11:33
Ohfishalee wrote: 23 Aug 2022, 01:19 Trying to select correct rear shock absorbers for VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Thank you. This is helpful.
x 6946
eurofjr wrote: 23 Aug 2022, 22:07 Hope everyone is having a good week. Almost the weekend!
Best,
Jim.
Item (20), Belt Part: 9803580580 (K6-LE 962), £34.09
Item (50) Belt Roller Kit and Belt
OEM Original Kit, Part: 1611503880, £43.79
Item (4) Alternator Pulley is not shown as available separately for the vehicle.
eurofjr
(Donor 2022)
x 4
Much appreciated!
x 3296
Please can I have the part number for the engine bay fuse box?
x 6946
@Hell Razor5543
Engine Fuse Box, Part: 6500CK, £319.63 inc. VAT
x 3296
Thank you, Marc
Huskyxantia
x 920
Unread post by Huskyxantia »
Hi Marc I'm needing part name and possible prices , cant remember what its called, my condition hinders me at remembering stuff at times.
Many thanks
:-D
x 6946
No problem, here you go. I've inclided the O Ring and sleeve, but the resonator (10) looks like it may already include the O-ring.
Item (10) is the Intake Air Resonator and is part of the Turbo Air Piping. Part: 144061, £77.11
Item (11) is the O Ring, Part: 144081, £2.38
Item (1) is the sleeve, part: 0382EN, £53.39
All VAT inclusive and available direct from Peugeot.
Huskyxantia
x 920
Many thanks Marc .
:-D
