Reached the bottom of my lane , warning on screen light on dash , ive been waiting for this , my outlet manifold is blowing which i think has caused said fault codes , were leaking gas were gulping air... Any pointers if i maybe wrong,
Egr is new original part. Ive soot upside the turbo which leads to outlet manifold and this is the route its taking.
206cc 1.6hdi
Dash board notification messages.
Huskyxantia
- x 888
Re: Dash board notification messages.
Husky.
- x 6955
Codes:
| Fault Code: | P0238 |
| Description of Fault: | Turbocharger pressure signal : Short circuit to positive. Short circuit to positive or open circuit Value too high (Above 4.8 V)For 1,2 second. |
| Conditions for Fault to clear: | Ignition on |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0401 |
| Description of Fault: | Air system fault : Measured quantity of air higher than the setting. Discrepancy for 10 seconds between the air flow setting and the measured air flow. - Engine speed between 750 and 2750 rpm |
| Conditions for Fault to clear: | Vehicle driven for 5 minutes, remaining below an engine speed of 3000 rpm |
| Downgrade Modes whilst Fault is active: | Deactivation of diagnosis of coherence on the flowmeter |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0409 |
| Description of Fault: | Electric EGR valve position copy signal: Valve sticking during the initialisation. Valve sticking for 8 seconds during the initialisation of the powerlatch (between switch off using the key and the ECU going to sleep). The following conditions have to be met: - The engine coolant temperature should be between 10 and 100 ° C - The battery voltage has to be between 10 and 15 volts |
| Conditions for Fault to clear: | Driving for 5 minutes |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
Huskyxantia
- x 888
Thats give a few answers to what im experiencing , looks like a few hours tinkering is due . Thanks for the code tables marc very useful.
Husky.
Huskyxantia
- x 888
Im smoking when i pull away ive that grunt blowing sound the smoke is dirty ,it clears fast. Im thinking oil is passing through the turbo so it looks like i might have to have an oil catch can before the turbo. Im not losing much power the turbo kicks in nice when needed.
Husky.
Huskyxantia
- x 888
Works when the car is immobilised, kids in the area love watching it slowly sweep side to side.
Husky.
Huskyxantia
- x 888
Started the tinkering today , top & bottom nuts on the front manifold one was finger tight the bottom was half way out a lable on the new dpf had nicely burnt off covered everything with ash , ive oil here there and everywhere to sort out photos tell what sort of a morning ive had. Having a break now a cup of tea & let the shower pass then back out to clean up and put everything back in. So much to move to get to work on this car its unreal.
Husky.
- x 2328
As a fellow 1.6 HDi in a 206 tinkerer, I can confirm, yes everything is crammed in. Notably highlights include a bolt between gearbox and engine block that needs the DPF removing to allow access. Air filter is a pain to get at (though it's worse with the 1.6 HDi in a Citroen C4 though - tucked even more under the windscreen!)
Unless you have already removed them, you've a couple of heat shields missing - one above and another below the exhaust manifold. Actually that's another "how the heck is this supposed to come out? That big heat shield running down the front of the DPF is such a pain to get out too!
It's a lovely engine in a nice little, light 206 - good fun
Matt
Matt
- x 2328
There are ways of improving access of course.....
Huskyxantia
- x 888
Like it .
Husky.
