Hi
Does anyone have a clue as to the OE part number of hose connecet to the marked part in the picture?
Thx
Part number Help needed THP 1.6 156/165
508c5
- x 4
- x 1438
Re: Part number Help needed THP 1.6 156/165
If I remember correctly, that hose goes to the fuel vapour purge valve.
508c5
- x 4
I think you are correct, I just need it's part number...
- x 6955
If you need part numbers, just put your request here in future:508c5 wrote: 20 Aug 2022, 20:42 Hi
Thx
viewtopic.php?t=69962
I have your VIN, and the diagram you have posted above is not for your vehicle. Your 508 has this:
If for another vehicle, please provide the VIN
508c5
- x 4
It has both
- x 6955
I've looked at the Turbo Air piping and I can't see any pipes.
508c5
- x 4
Well, it's there
i just can't find it on any drawing
U can see its the correct one for my Vin and u can see that it's not on the drawing...a mystery..
It "sweating" oil, I want to replace it
- x 1438
Look at the diagram for the fuel system, it should be one of the 3 hoses attached to the purge valve.
- x 1484
Probably this? Comes complete with the valve at £75...
The pic you posted Marc is the inlet to the air filter, the air pipe is the outlet from the filter under Turbo Piping, and the purge valve under Emission Control - Canister Depollution Absorber
508c5
- x 4
Yes ! Thank you both !
Looks like an easy unscrew/screw back job...or not..?
508c5
- x 4
Where is the quote (75£) taken from?
- x 1484
That's the dealer price from servicebox - almost certainly available elsewhere cheaper!!
- x 6955
Well done on that one Richard!
