- x 3304
Thank you.
moomoo
- x 9
Hello,
Could you provide the part number for the 2nd gear on the ML5T gearbox... It's a 1998 Boxer. Do you know if this part is still available?
- x 6956
@ moomoo:
For parts we require the VIN.
moomoo
- x 9
Hello again...
I submitted a post on 17 December 2020 at 13.08 with the VIN and REG numbers. of the donor vehicle ..It's been partially hidden so staff can view it but not the public.
Do you still have those details of the VIN?
The REG is ....WV02 BWF
The donor motorhome will have long since been crushed with all its ID....therefore there's no possibility of retrieving the info.
Fingers crossed!
- x 6956
Ok, I've got it recorded now for future:
This is all I can see, 2 diagrams:
First Line Manual Gearbox
(2), (5) & (70) are the only items available.
Second Line Manual Gearbox
Only (5), (11), (16), (20), (22) & (24) are available on the second diagram.
Let me know if you need part numbers for any of these or the other items.
99xantia
Good morning
I’ve been looking at shock absorbers but some seem specific to each variant and a lot of people list those NOS types with no specification of said variant.
Would it be ok to get part numbers for front shocks and springs please before I buy something useless?
Thank you.
Thank you.
- x 6956
@99xantia:
Front springs: Several possibilities - you should compare with existing markings to confirm which you have:
Item (1)
Part: 5002HS (REF 3 RED 1 BLUE OR 2 RED 2 BLUE - 6 5 COILS), £155.02
Part: 500235 (REF 2 GREEN 1 RED OR 2 GREEN 1 YELLOW), £155.02
Part: 5002A9 (REF 3 GREEN 1 BLUE OR 2 GREEN 2 BLUE) No longer available
Front Shock Absorber
OEM
(1) Left Part: 5202EL No longer available
(1) Right Part: 5202EN No longer available
Cheaper Part: Left 1635540780, £56.94
Cheaper Part: Left 1635540380, £56.94
Only if you have the height adjustable variants:
Left Part: 1635540280, £56.94
Right Part: 1674697880, £56.94
Item (1)
OEM
99xantia
Excellent. Thank you ever so much. Prior to removal I can see red so this will all be helpful.
Thank you.
Thank you.
Orchid70
- (Donor 2021)
- x 6
Hello Marc!
Hope you are not melting away.
Looking to know what type of additive, perhaps additives, this Partner II from 2016 has:
Reason: Split Tech Query Off to Peugeot Tech Forum
- x 6956
No nice & Cool here
You need Powerflex Additive and you have a hard reservoir tank fitted not a pouch system.
I'll split the fault codes off into a separate topic in the technical section and put a link back here after pointing to the topic.
Link to your Technical Query:
viewtopic.php?p=726735#p726735
Orchid70
- (Donor 2021)
- x 6
Marc - when Im looking for the new pump - can you give me the part number?
- x 6956
Sure, here you go, the pump is incorporated into the additive tank. But very unusual for the additive pump to fail twice! I would check everything else first to be honest, as there may be an issue with the pipes themselves getting compressed and cutting off supply or with the electrical supply. If it is something like this, then replacing the tank and pump assembly won't cure the problem if it's in the supply pipes or the electrical circuit.
Item (30) Part: 9816296080, £242.06 inc UK VAT (so the equivalent in Sweden).
KennyW
- x 164
Marc,
Looking for the correct part number for the engine harness (20MOT)
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6956
I believe 20 MOT is the Engine Harness. Let me know if other.
Item (1) Part: 6585F5, Engine Electric Harness (Marking 9672299380), No Longer Available, but was £669.80.
Item (2) Part: 658557, Injection Harness (Marking 9688246780), £31.81.
ninulus
Hi everyone. I'm a new member, I've just came across this forum in my endless search on internet...
I need a part code for my gearbox.
I have located the code on my gearbox, it's 20CQ27, but I can't find a gearbox with the same code here in the UK. Can anyone tell me a compatible gearbox with a different code, maybe I'm lucky and I can find something...
And if the VIN helps, mine is VF3**************[VIN obfuscated, can be read by forum staff].
Please help...
Please help...
