How to Replace the Internal MicroSD Card - RT6
mohammad_jhd
- Locked user account
Re: How to Replace the Internal MicroSD Card - RT6
Thank you for helping me
Because it doesn't work anymore, I formatted the memory card and reinstalled it, but it gave an error again
- x 6945
I suspect the errors relate to your source media. Either you don't have a genuine update CD from the dealer or are using a copy from the internet. These are usually the issues with CRC errors - the media has data integrity issues.
I suggest you buy a genuine update CD from the dealer, they only cost a few £s and will ensure you have a decent media source before starting the operation.
gast3d
- New User
phaj_hybrid4 wrote: 08 Apr 2022, 13:26 Hi Marc,
The unit information are the following:
MM-BTEL RNEG2 CEM00 - MAN.DATE 2013/07/09
REFERENCE 98067084477
CD NUMBER: 8639
SOFTWARE VERSIONS:
RNEG2.75C5
201212051200
BR:6.2.70.10:pr
CD_FW:35
FP:06.01.d1
GSM:---
AVR DB:0
GPS:GSW2xr-2
RD:RMM
BT:5.20.1
138d 10h38
HDD 0d 0h0
dbdwnl:313
Grpo4:61
Thanks,
Paris
Hello! How are you? I'm from Argentina, I have the same problem. What firmware do you have installed for it to work? could you share me the ZIP?
Thank so much
- x 6945
@gast3d
I've sent you a PM
I've sent you a PM
omseebii
Hello how is everyone !
I jus got a Peugeot 308 2013 with blank screen , radio not working , odometer is in km instead of mph , the radio makes a noise like ejecting a cd and I have seen a few posts about it but I don’t have the service history of the car
What’s is the solutions?
Is an aftermarket android worth it ?
mohammad_jhd
Hello good timeGiveMeABreak wrote: 03 Jul 2022, 09:23 I suspect the errors relate to your source media. Either you don't have a genuine update CD from the dealer or are using a copy from the internet. These are usually the issues with CRC errors - the media has data integrity issues.
I changed the memory card and installed the operating system, but because the previous memory was broken, I could not take a backup through mirascript. Is it possible for one of the friends of this forum to take a backup from his car and send it to me to install it? Because now some features of the device are not working
Thank you for your help
my car peugeot RCZ 2014 1.6 petrol
mohammad_jhd
From the friends PEUGEOT RCZ 1.6 of the forum, if anyone can send me a backup of Mirascript to solve my problem. thanks a lot
- x 6945
That won't help you to be honest as each member's vehicle may be different to yours with different options and equipment, and in addition will have their personal files stored on the system Contacts etc.). As options will differ from vehicle to vehicle you will still have an issue. The best thing you can do now is to get to a dealer and get them to set configure the RT6 from their servers that will have the correct options for your vehicle.
mohammad_jhd
Well, I will tell you the options my car has, maybe it is the same as your carGiveMeABreak wrote: 06 Aug 2022, 23:46 That won't help you to be honest as each member's vehicle may be different to yours with different options and equipment, and in addition will have their personal files stored on the system Contacts etc.). As options will differ from vehicle to vehicle you will still have an issue. The best thing you can do now is to get to a dealer and get them to set configure the RT6 from their servers that will have the correct options for your vehicle.
Because I am Iran and Peugeot does not have a representative here
I do not know what to do!!!
mohammad_jhd
VIN Number My Car:
Onlinemyglaren
- x 5672
A Citroen dealer may be able to help. We have found the opposite here where there is no local Citroen dealer that a Peugeot dealer can supply parts and may be able to advise on other matters too.mohammad_jhd wrote: 07 Aug 2022, 00:21 Well, I will tell you the options my car has, maybe it is the same as your car
mohammad_jhd
There is no PSA dealer inside Iranmyglaren wrote: 07 Aug 2022, 07:56A Citroen dealer may be able to help. We have found the opposite here where there is no local Citroen dealer that a Peugeot dealer can supply parts and may be able to advise on other matters too.mohammad_jhd wrote: 07 Aug 2022, 00:21 Well, I will tell you the options my car has, maybe it is the same as your car
- x 6945
Your best bet is to try on one of the navigation forums where you may have more success.
luis600
I have managed to save rt6 with new micro sd card and installation of new firmware. As expected everzthing is now messed up buttons are not working/different logo etc.GiveMeABreak wrote: 22 Feb 2022, 11:45If it has been successful you will have a working system with your original options.
- Once you have installed the new firmware from the CD and it has booted, you can switch off the system remove the MicoSD card and then copy the user data folder back into the correct original partition and location, reinstall the Micro SD card and restart the system.
I somehow retrieve files from my old sd micro card under user_data\User_profile.
So now I need to copy paste all these files
- Spoiler: show
to the new micro sd card under this section user_data\User_profile, remove hidden folder System Volume before ejecting sd card from pc and put back micro sd into the device. After this everything will work as before? Please confirm
- x 6945
That's the purpose of the Mirascripts part A as shown in the main guide:
viewtopic.php?p=610017#p610017
However if you are unable to retrieve the files via the normal way, I can't say whether this will work or not. I would just keep notes of what you have done.
