Security wheel nut better than OEM?
Ross_K
x 110
Re: Security wheel nut better than OEM?
Unread post by Ross_K »
GiveMeABreak wrote: 24 Jul 2022, 11:56 I think the topic is moving off the original question asked - not whether they are a good idea or not, but whether there are alternatives to the OEM ones are better or not.
McGard seem to have a good reputation generally
Less possibility of failure compared to the PSA 3-pin design anyway...
x 6947
Indeed - anything has to be better than having thin pins that are doomed to break off under any type of force.
C5_Jack
Unread post by C5_Jack »
Hello All
Thank you for all your comments.
My alloys are in needs of a full refurb so the monetary value is not an issue.
I took a non security bolt from the car and I cannot see a part number on it.
I have found this on FEBI's website, FEBI part number 46673
https://partsfinder.bilsteingroup.com/e ... 20204%20hp.
Would this be the OEM bolt?
Jack
x 3298
I would save yourself a bit of money and visit your local scrap yard. It should only be a few quid for 4 bolts. ASM (off J7 M40, close to Thame) probably are your closest. I did this with a previous car, and then put a thin smear of copper-slip grease on the threads, to make sure they did not seize in place.
x 1943
When getting replacement bolts check what size spanner or socket you need for undoing. There are two sizes, 17mm and 19mm, and while the thread and other dimensions are the same it's a pain having to keep two sockets ready.
x 6947
C5_Jack wrote: 30 Jul 2022, 16:46 Hello All
Jack
No Jack, they're not the correct ones for your car.
You need these:
https://www.ebay.co.uk/itm/332663182525
C5_Jack
Thanks Marc
Ordered
x 1943
Did you check that the spanner size needed is the same as the bolts already fitted to the car?
x 6947
They are listed with the same part number as his originals.
x 1943
Let's hope they are the same size then.
