x 6955
Drivehsaft
Driveshaft Right, Part: 3273WW (MARKING 8MN24), £555.43
Cheaper exchange part no longer available.
Rear Arms
You'll need to be a bit specific as several components are referred to as arms:
(1) is the Trailing Arm, Left, Part: 9650668480, £359.15
(2) is the Rear Suspension Arm
OEM Part: 5175CF. £195.58
Cheaper Alternative, Part: 1682738780, £27.79
If any other part, let me know, like (3) Rear Longitudinal Arm....
Heat Shields
There are 6 heat shield parts.
Item (1), Part: 1723V7, £41.45
Item (2), Part: 1723AV, £44.05
Item (3), Part: 1723YJ, £54.05
Item (4), Part: 1723T8, £101.02
Item (5), Part: 1723T9, £50.62
Item (9), Part: 1723Z0, £20.33
moizeau
x 429
Unread post by moizeau »
Thanks Marc, I think it's No. 73 for the heat shield, which from the drawing looks like a nut. The drop arm is this I think https://www.piecesauto24.com/ridex/8000242 and the track rod end is this ( I think) https://www.piecesauto24.com/ridex/8221103
Thanks Marc
Pete
x 6955
moizeau wrote: 11 Jul 2022, 18:11 Thanks Marc, I think it's No. 73 for the heat shield, which from the drawing looks like a nut. The drop arm is this I think https://www.piecesauto24.com/ridex/8000242 and the track rod end is this ( I think) https://www.piecesauto24.com/ridex/8221103
Thanks Marc
Ok, so the rear Anti Roll Bar Drop Link.
Item (4)
OEM Original, part: 9807130080, £67.19
Cheaper Alternative, part: 1634904380, £12.61
Heat Shield
Item (73) previous diagram, Heat Shield Flanged Nut (6X100), Part: 6936C9, £1.07
Steering Rod Ball Joint Kit
Item (5)
OEM Right Side Kit, Part: 381766, £104.65
Cheaper Kit, Part: 1682735680, £30.90
Huskyxantia
x 888
Unread post by Huskyxantia »
Marc , part number for the steering rack for my 307sw theres slight play in mine my vin VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks.
:-D
moizeau
x 429
Thanks very much Marc.
Pete
x 6955
Huskyxantia wrote: 12 Jul 2022, 10:24 Marc , part number for the steering rack for my 307sw theres slight play in mine my vin VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Ok, so there are several options here for the rack.
The original OEM rack was part: 4000ZQ, £859.26
This has been replaced with a later part: 1617933980, £1,273.87, however if using this replacement rack, it also requires 2 new steering ball joints, Part: 381750 @ £53.76 each.
The alternative cheaper refurbished rack is part: 1663652180, £744.48.
Huskyxantia
x 888
Thats for the steering rack post, Is there any diagram and part numbers of the complete exhaust system for my 206cc, 1.6hdi. From manifold to back box , its blowing somewhere sounds like a joint may need welding its front & low down. Cheers Marc
:-D
x 6955
I can't see any recent request for exhaust so didn't include it.
Exhaust system (intermediate and rear), if you need the catalytic converter and particular filter units, please advise.
(1) Rear Silencer
Part: 1726VW, £286.16
(3) Intermediate Pipe
OEM Part: 1717EJ, £319.34
Cheaper alternative, Part: 1609222780, £220.22
(2) Clamp, Part: 171366, £10.19
Huskyxantia
x 888
Cheers Marc, yes please id like the cat and dpf too, give me a rough idea the sort of costs then.
:-D
x 6955
@Husky: To save time later, here are the other components:
(1) Exhaust Manifold, Part: 0341J2, £314.62
(2) Manifold Gasket, Part: 0349N0, £6.22
(11) Catalyst
OEM Part: 1731EN No longer available
Cheaper Alternative, Part: 1609159680, £519.32
(12) Particle Filter
OEM Part: 1731JL, No Longer Available.
Standard Particle Filter Part: 174024, £625.26
Cheaper Particle Filter, Part: 1611322880, £535.07
Huskyxantia
x 888
Brilliant Marc , many thanks just what i needed . Cheers.
:-D
Jassooo
(Donor 2022)
Unread post by Jassooo »
Hello Folks, I have a Citroen C4 1.6hdi year 2007 with possible ABS unit issue. Can you assist with correct partnumber/Citroen OEM number for the ABS unit/pump please? VIN VF7**************[VIN obfuscated, can be read by forum staff]. Thanks and sorry for forum errors due Im a newbie here.
x 6955
Hi. The module is shown as a complete unit (ECU and Hydraulic Block).
Hydraulic Block Item (1)
OEM Replacement Part No: 4541FV, £1536.84
Reconditioned Part: 1682607080, £1510.21
All VAT inclusive direct from Citroen.
Just as an aside, I would first post up the specific issues you are having in the main Citroen technical section by creating a new Thread. Pop up any fault codes you may have there too, as many errors can be related to the ABS / ESP system without it actually being the hydraulic block / ECU itself. It's a lot of money to replace parts unless you are sure it's the module itself. :wink:
Jassooo
(Donor 2022)
Thanks Marc! Thanks also from the tip for the forum. I have couple of used units insight with 100e but just didnt know if they a compactible, plan is to have fault lights off and sell it asap 😬
KennyW
x 164
Unread post by KennyW »
Marc,
Looking for the part number for the alternator fitted to my C5 X 7 Vin No VFR**************[VIN obfuscated, can be read by forum staff]
Kenny
C3 1.4 petrol (SWMBO)
