x 6947
@ Husky: Please can you be specific in what exact items you require parts for as everyone has a different idea of a service :wink: I.e:
Oil Filter
Air Filter
Cabin Air / Pollen Filter
Fuel Filter etc.....
Huskyxantia
x 927
Unread post by Huskyxantia »
Sorry , oil, air, fuel & pollen for both cars, thank you :)
:-D
Huskyxantia
x 927
Would 10w40 be ok for the 307 , its a 2.0hdi, only the seller said he used magnatec 10w40, when i checked the part service history of the car it was 5w30.. confused now !
To be honest ive always used 10w40 in the 2.0hdi they always ran good with it . But...
Im usings 5w30 for the 206cc which seems to run fine.
:-D
x 6947
Leave it with me I'm preparing a post now..
x 6947
Diesel Filter
Filter and Seal Item (9)
OEM Original, Part: 1906A6 (100x80x80), £37.97
Peugeot Cheaper variant, part: E148135, £9.17
Air Filter
Item (2)
OEM Air Filter, Part: 1444TZ, £32.44
Cheaper Air Filter Part: E147241, £10.24
Oil Filter
Item (9)
OEM Oil Filter (Purflux), Part: 1109AL, £15.48
Cheaper version, Part: E149134, £7.01
Pollen Filter
Note
There were 2 possibilities for the Air Puller Fan that could of been used: Either a Magneti Marelli system or a BEHR France system. Each have different Pollen filters. I can't advise as to which system you have fitted, so it may be worthwhile pulling out the old one to determine the original markings / identification first. I have provided both types here:
Option 1 Magneti Marelli System
Item (7)
OEM Pollen Filter, Part: 6479C2, £30.72
Cheaper Version: E146155, £8.72
BEHR France Version
Item (7)
Only one filter available, Part: E146177, £18.16
As for Oil, any of the following are specified for this engine (DW10TD)
5W30 Oil B71 2290
5W40 Oil B71 2296
10W40 Oil B71 2300
Which one you use will depend on the protection you want.
Look at this guide here, bearing in mind the UK is a temperate country.
The first diagram shows the protection for the various grades - so pick one of the 3 grades I specified above and check out the protection for each, then you can decide:
https://frenchcarforum.co.uk/wiki/Citro ... arbox_Oils
206 Parts follows...
x 6947
@Husky@
206 Service Parts
Fuel Filter
Item (1)
OEM Fuel Filter Part: 190195, £56.88
Cheaper Filter, Part: E148068 £36.16
Air Filter
Item (1)
OEM Air Filter, Part: 1444TJ, £32.44
Cheaper Filter, Part: E147242, £9.54
Oil Filter
Item (8)
OEM Filter, Part: 1109AY, £16.82
Cheaper Filter: 1680233480, £9.34
Item (9) Oil Filter Cover, Part: 1103K4, £61.22
Cabin / Pollen Filter
Item (6)
OEM Carbon Filter, Part: 6447PE, £43.36
Cheaper Carbon Filter, Part: E146242, £24.47
Oil Recommendation:
Engine DV6TED4 (RHZ) With Particle Filter.
Any of these are acceptable - but again look at the link with the diagram as specified on my previous post to determine which best suits your needs for a temperate climate.
5W40 oil
10W40 oil
0W30 oil
5W30 oil
x 1496
Important to note that oil for a DPF equipped early 1.6 HDI should be C2 spec (later blue HDi need C1 spec)
Huskyxantia
x 927
This is excellent , i can't thank you enough.
:-D
Huskyxantia
x 927
My vin 307sw ,VF3**************[VIN obfuscated, can be read by forum staff] Marc can you confirm my fuel pump and injections are they siemens ? Many thanks
Also the maf sensor played up yesterday car went to limp mode , my thoughts were it got so hot under the bonnet the air temperature was to warm and maybe it couldn't work out what it needed to do so car came up with the mil light & anti poll fault. Its been ok since. Was rather hot yesterday were i was driving. Plus a part number for the maf sensor to , many thanks.
:-D
x 6947
Your Engine ECU and Injection Pump are indeed Siemens.
Item (9) MAF, Part: 19207S, £231.92
Huskyxantia
x 927
Many thanks marc.
:-D
x 1083
Unread post by Rp0thejester »
So I need to know what coolant is needed for my baby, VF7**************[VIN obfuscated, can be read by forum staff]. Also if this vehicle was sold in let's say Africa/Australia would it be the same coolant required?
x 6947
Rp0thejester wrote: 09 Jul 2022, 18:35 So I need to know what coolant is needed for my baby, VF7**************[VIN obfuscated, can be read by forum staff]. Also if this vehicle was sold in let's say Africa/Australia would it be the same coolant required?
PSA use the same type for the vehicles now except for collaborative vehicles listed below:
  • (C1 (B1) / 108 (B1) - (1.2 -litre petrol engine)
  • C-CROSSER (I4) / 4007 (I3) - (2,2 litre HDI engine)
  • C4 AIRCROSS (J4) / 4008 (J3) - (Petrol and diesel engines)
  • C-ZERO (S4) / IOn (S3)
  • E-Méhari
  • PEUGEOT PICK UP (KP0)
  • Commercial vehicles
Either the Freecor DSCAntifreeze available in 1, 20 or 210 Litre containers.
or
Freecor DSCFluid (ready for use) available in 2, 5, 10 or 20 Litre containers.
Regardless of country, apart from France for which there some unknown differences as the name is the same but the product numbers are different.
x 1083
:whip2:
moizeau
x 423
Unread post by moizeau »
My 407 has just passed it's CT with a couple of advisories, Fr RH track rod end and Rr LH drop arm. Also during my latest trip to the UK the heat shield has fallen onto the back box. The welded studs are still present but not the fasteners. Could you look up the OEM part nos. please Marc for the 3 items?
I could use a standard metal clip but it would be a bugger to remove so was wondering if in fact they are plastic?
Cheers
Pete
