admiral51
- (Donor 2026)
- x 391
- x 6956
I can only advise you about what is showing on the live parts database Colin unfortunately, and I can't locate that part at all.
dulenator
- x 11
Hi all!
Can you please give me the part numbers for those three rubber seal thingies for the rear suspension cylinder ram?
I found these on eBay, but I'm not sure if they are the correct ones for my car.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
admiral51
- (Donor 2026)
- x 391
Thanks Marc i totally understand think i will phone a couple of other dealers and see what response i getGiveMeABreak wrote: 03 Jul 2022, 23:26 I can only advise you about what is showing on the live parts database Colin unfortunately, and I can't locate that part at all.![]()
I dont suppose you pop up a diagram/picture of the part so i can compare.
- x 6956
Here you go Colin. item (13).
- x 6956
No worries:dulenator wrote: 04 Jul 2022, 16:56 Hi all!
Item (7), O-Ring Diam 40 E 3, Part: 527228, £2.29
Item (8), Suspension Cylinder Sliding Ring Diam 40 E 3, Part: 527230, £6.54
Item (9), Weatherstrip, DIAM 41X47 E 2,4 Part: 527232, £3.12
All VAT inclusive from Citroen.
ianb875
Xantia exclusive 1998 VIN VF7**************[VIN obfuscated, can be read by forum staff]
Indexing mirror
Part number please for electric control module inside the nearside front door.
I have made a donation, a few minutes ago. Thanks IAN BRAWN
Indexing mirror
- x 1056
Part number is 96133204 but is showing as no longer available from Citroen I'm afraid. It was just over £300 inc VAT
- x 1056
Strange, It does come up as a legit part number (Listed as a Seal & is £13.55 + VAT) But as Marc says it's not allocated to any Citroen, Peugeot or DS vehicle?admiral51 wrote: 03 Jul 2022, 20:14 Thanks Marc maybe i have got wrong part number but if this works the picture is what i have been given, i did post in another thread earlier and do not want to double post but gut says it is the wrong part.
Huskyxantia
- x 900
Hi marc,can these still be found , Door protector moldings for a citroen zx estate and how are they fitted to the door ? Vin can be posted if needed, cheers.
Husky.
dulenator
- x 11
Thanks! Less expensive than refilling the system all the time.GiveMeABreak wrote: 04 Jul 2022, 20:21
- x 6956
Item (16), Left, Part: 96082770ZQ, No longer AvailableHuskyxantia wrote: 04 Jul 2022, 22:49 Hi marc,can these still be found , Door protector moldings for a citroen zx estate and how are they fitted to the door ? Vin can be posted if needed, cheers.
Right, Part No: 96082769ZQ, No longer Available
Item (1) No longer Available.
Can't advise how these are fitted I'm afraid, but the outside rubbing strip is clipped onto what I think is the protections trip which itself is rivetted peg or welded peg head fitted.
admiral51
- (Donor 2026)
- x 391
It does look very similar to the picture for part #13 so i am going to go back to my local dealer to get written clarification that the part number is in deed correct so when i send it in to get the work done if does not fit i have some comeback.wheeler wrote: 04 Jul 2022, 22:26Strange, It does come up as a legit part number (Listed as a Seal & is £13.55 + VAT) But as Marc says it's not allocated to any Citroen, Peugeot or DS vehicle?admiral51 wrote: 03 Jul 2022, 20:14 Thanks Marc maybe i have got wrong part number but if this works the picture is what i have been given, i did post in another thread earlier and do not want to double post but gut says it is the wrong part.
Thankyou all for your help, will reply in main post not here to avoid spamming the thread .
Colin
- x 6956
Thanks Colin
Huskyxantia
- x 900
Thanks for the zx door trim info marc , the new daily is soon due its service any service kit numbers i need to know about ? My vin is VF3**************[VIN obfuscated, can be read by forum staff], when i had the picasso some places i used to get the service items from would give me the wrong fuel filter .
Better do the 206cc aswell , vin is. VF3**************[VIN obfuscated, can be read by forum staff]
Thanks marc.
Thanks marc.
Husky.
