Whatsthisthen?
Re: Whatsthisthen?
Proper whatsthisthen :?:
whatsthisthen?
whatsthisthen?
Heardle-esque points scoring I will not be curating guesses, but how did you do?
no clues correct 50 points
Clue one revealed 40 points
Spoiler: show
Purchased by the first registered UK owner in 2003 when it was driven through Sweden to Gothenburg, ferried to Newcastle and thereafter remained, unused at it's home in Devon
Clue 2 revealed 30 points
Spoiler: show
It was sold at auction in the UK in 2019
Clue 3 revealed 20 points
Spoiler: show
try an enquiry here https://www.glenmarch.com/cars/results it was sold for £1,100 in August 2019
Clue 4 Revealed 10 points
Spoiler: show
It was sold at Anglia Car Auctions
The answer....nul points
Spoiler: show
ZAZ 968M 1989 from Latvia
x 8141
Re: Whatsthisthen?
TOH - it's either an NSU Prinz or a ZAZ from eastern europe? :)
Re: Whatsthisthen?
mickthemaverick wrote: 30 Jun 2022, 10:57 TOH - it's either an NSU Prinz or a ZAZ from eastern europe? :)
Go down the clues and see if you are right and claim the appropriate points. I would say for heardle you always need artist and song title, ditto for this whatsthisthen? 50 points still available to you for a researched answer (make and model) without using the clues.
x 8141
Re: Whatsthisthen?
A bit of research following my thoughts has turned this up:
Screenshot
Screenshot
So I would say it is one of them and claim the 50 points!! :-D
Re: Whatsthisthen?
mickthemaverick wrote: 30 Jun 2022, 11:38 So I would say it is one of them and claim the 50 points!! :-D
You know you have it, did you twig the reg its a Devon TA plate, which is how I found it. Follow the clues and you will pull out the actual car, and what it sold for.
x 8141
Re: Whatsthisthen?
No I didn't see the reg but at £1100 I would have to say that was a bargain for someone - could be worth a lot of money one day!! :-D
Re: Whatsthisthen?
whatsthisthen?<br />The Clackmannanshire registration is not a clue
whatsthisthen?
x 8141
Re: Whatsthisthen?
TOH - looks a bit like the Haflinger ICI used to run as their field maintenance vehicle? :)
x 8141
Re: Whatsthisthen?
Which it clearly isn't!!
But you can see why I thought it might be!! :-D
Re: Whatsthisthen?
mickthemaverick wrote: 16 Jul 2022, 18:17 TOH - looks a bit like the Haflinger ICI used to run as their field maintenance vehicle? :)
4 &quot;words&quot; on the badge,  and Haflinger not one of them.  The two &quot;words&quot; at the top are hyphenated
4 "words" on the badge, and Haflinger not one of them. The two "words" at the top are hyphenated
x 8141
Re: Whatsthisthen?
How about a Simca Marmon? :-D
Edit: possible 4 words on badge: Simca Unic Marmon Bocque
Re: Whatsthisthen?
mickthemaverick wrote: 16 Jul 2022, 18:26 How about a Simca Marmon? :-D
Yes very quick and very right<br />SIMCA wanted a commercial vehicle production unit and took over UNIC in 1952<br />The truck is a 1959 example and was designed by Bocquet  hence its full moniker<br />SIMCA-UNIC Marmon Bocquet  quite a rarity in deepest Northumberland.
x 2938
Re: Whatsthisthen?
Looks about right Mick, at first glance it reminded me of the Ford WOT 6 trucks we had in Egypt.
Re: Whatsthisthen?
More a Where's this then :?:
whereisthestation
whereisthestation
Re: Whatsthisthen?
NewcastleFalcon wrote: 29 Jul 2022, 10:49 More a Where's this then :?:
6 hours and no one has even written their name on the top of the exam paper.
Its not impossible, and help will be given with each guess.
To narrow it down and give you a hint, Its on the London Underground Map. The roundel tells you that :-D
