- x 5669
No photo's but there were loads of dead deer by the roadside when I was last in Northallerton.
Must have been a dozen in a fairly short stretch.
- x 1240
I put in 'the woods' but as you may have noticed they have just felled all the trees, some larch infection, so there is not a lot of cover for the deer now.
- x 5669
First attempt at slide copying, taken about ten years to get round to it. Tidying up a bit I found some slides chucked in a drawer.
I want to think that this was taken in York but it is more likely Gothenburg. Not many wear Swedish clogs in York.
- x 1240
How do you copy them?
- x 3302
Lidl recently did a Negative/Slide convertor for £25. Basically it is a specialised 'scanner' that scans the negatives (or slides) and then allows you to save them to your computer. I bought one for myself, and another for a friend.
- x 8082
Is yours this sort of thing James?:
https://www.ebay.co.uk/itm/403656026367 ... SwDdBiffrn
- x 3302
Nope, more like this (but not this);
https://www.ebay.co.uk/itm/134156041739 ... Sw2TBird8D
It was the one I posted the link to in the Aldi/Lidl thread.
- x 8082
Right, I've just realised that the one I posted is only really a backlit film/slide holder. You need to use a phone camera to actually copy the image!! A bit misleading but I think this is the right thing that connects via USB:
https://www.ebay.co.uk/itm/265733870300 ... SwRTVipfcU
- x 3302
Yes, that looks like it. The one from Lidl was £25, own make (SilverCrest), and has a 3 year warranty.
- x 7164
Lovely moment Peter and an excellent POTD I presume its a Roe , they don't keep their Bambi spots very long. Only seen one very young one with spots, and yes it was in someones rather large garden without camera to hand.
- x 1240
Yes Roe deer. I can't claim the credit, my son saw it as he was coming in.
- x 5669
Is it any good James?Hell Razor5543 wrote: 26 Jun 2022, 21:13 Lidl recently did a Negative/Slide convertor for £25. Basically it is a specialised 'scanner' that scans the negatives (or slides) and then allows you to save them to your computer. I bought one for myself, and another for a friend.
I used a projector and screen.Peter wrote: How do you copy them?
I have loads of 6x6cm slides and scanners for those are very pricey.
- x 1240
That's how I did it last time, went very well until I downloaded them on to my computer and they all dissapeared! Mine are 35mm and I have hundreds, can't remember where or when some of them were taken. Sadly some of the best ones have deteriorated with loss of some colours.
- x 3302
Yes, it is. It has the ability (in the software) to adjust the colour balance, so if you have a negative that has had a colour distortion you should be able to compensate for it.myglaren wrote: 26 Jun 2022, 22:13Is it any good James?Hell Razor5543 wrote: 26 Jun 2022, 21:13 Lidl recently did a Negative/Slide convertor for £25. Basically it is a specialised 'scanner' that scans the negatives (or slides) and then allows you to save them to your computer. I bought one for myself, and another for a friend.
- x 5669
Thanks James.
I do recall you mentioning it some time ago and meant to get one, then as usual forgot. Will keep a look out for them as using a projector and screen degrades the images somewhat.
