DTC P3064 MOTORISED THROTTLE UNIT ADDAPTIVE AT LIMIT
508c5
x 4
Unread post by 508c5 »
HELLO,
Can anyone maybe shed dome light over this DTC ? tried to look up info on-line but failed till now. its a Peugeot 3008, 1.6 THP, 165 bhp (2016). Car is riding ok, nothing feels wrong.
it comes together with P3065 AND u0103 (no communication with gearbox) and U0140 (no communication with BSI). best i could find is that it might be connected to a weak battery...
thank you.
x 3303
Re: DTC P3064 MOTORISED THROTTLE UNIT ADDAPTIVE AT LIMIT
It is known that a failing battery can cause all sorts of weird and apparently unrelated problems. Modern PSA vehicles have a lot of electronics, and they rely upon a battery in good working order. I would get the battery tested before replacing any parts. If the battery is the original one it is now 6 years old, so probably a bit elderly.
508c5
x 4
thx, as i said, i am aware of the battery issue however, if this is a real error i'd like to know more about it...
x 6956
Leave it with me and I'll advise shortly... but first I will need the VIN of the 3008 for a correct fault descriptor.
gwest
x 20
Unread post by gwest »
In the case of my 2013 DS5 THP155 with throttle errors at 85,000 km it turned out to be a faulty throttle body. Pretty poor really but then a lot of plastic parts fail on these cars.
nightlordccc
New User
Unread post by nightlordccc »
508c5 wrote: 13 Jun 2022, 12:01 HELLO,
thank you.
Hello 508c5 & everyone, hope all is well.
Did you solve the issue ?
I'm driving a 308 T9 1.6 165bhp assume it's the same engine as yours.
I've encounter this error too. Problem starts during wide open/full throttle, the car hiccups acting like it's cutting fuel intermittently or traction control kicks. Mechanic changed a throttle unit but I can still feel it.
Cheers
508c5
x 4
nightlordccc wrote: 07 Feb 2023, 04:22
thank you.
Cheers
Went away after changing of the battery
